New terminal on RB433.
type: export
copy/paste to the notepad.
delete all setting related with MACs of the board, and keep only other configurations.
delete all settings related to ether2 and ether3 because RB133 don’t have this ports..
Copy paste the result to the RB133.
Additionally to Martin comment, I would recommend to edit export file, and leave only important part of the configuration, while default/unused settings could be deleted.
ok.
You explained me how to export the settings. But how do i Import it then to the new board? Which command do i use?
Please explain me more detailed.
Pretty much. Not only is it best practice (to the point that running a PKI without following this best practice is completely pointless) to revoke any certificate signed with a private key the owner has lost control of, it is also mathematically impossible to derive the private key from the public key (the certificate is the public key) because that’s the entire point of asymmetric encryption: anyone can see your certificate but cannot possibly derive your private key from it.
For what it’s worth, if you have your own PKI revoking and issuing a new certificate is free and quick, and pretty much any seller of certificates will let you do the same thing via some web interface. Like I said: everyone revokes certs when private keys are lost, and a key would count lost if someone had stolen your AP. Certificate authorities are well set up to reissue new certs.
