Noctis
November 10, 2023, 5:57pm
1
I apologize for the stupid question, but tell me what I’m doing wrong, how to install this container on hap ac2:
https://github.com/linuxserver/docker-transmission
I found a version for Arm v7, but I can’t figure out how to install it correctly:
https://github.com/linuxserver/docker-transmission/pkgs/container/transmission/97348102?tag=arm32v7-latest
git clone https://github.com/linuxserver/docker-transmission.git
cd docker-transmission
docker build \
--no-cache \
--pull \
-t ghcr.io/linuxserver/transmission:arm32v7-latest .
docker save ghcr.io/linuxserver/transmission > transmission.tar
At the end I get a container for amd 64 architecture:
According to that github page it is only x86 or arm64.
elico
November 11, 2023, 9:09am
4
If you are using some kind of torrent software you should look at qbittorent rather than transmission.
However for hap ac2 I would try to use only transmission if at all and with a limited amount of ram.
Noctis
November 11, 2023, 12:23pm
5
I’m just learning to use docker and containers, so far I haven’t succeeded
I managed to install this version:
https://hub.docker.com/layers/linuxserver/transmission/arm32v7-4.0.3/images/sha256-7a26be6046832b5e93a100bc913a9248beac685e233824a9bac68bb1572d05d4?context=explore
download speed 0.5-2.5 mb, processor load, ram:
But I’m using an old and slow flash drive for the test, it will be interesting to play on an SSD/HDD
And I can’t understand where the download is going and how I can access these files, I have a samba server container, but so far I have no idea how to use them together
smth like that?
https://github.com/qbittorrent/docker-qbittorrent-nox
elico
December 2, 2023, 8:59am
6
@noctis .
YES, this is great!!!
