Transparent Bridge, using EoIP tunnel - How-to question!
Last step:
Move the IP addresses from Ethernet to bridge interfaces:
[admin@AP] ip address> set [find interface=ether1 ] interface=bridge1
[admin@AP] ip address> print
  #   ADDRESS            NETWORK         BROADCAST       INTERFACE
  0   10.0.0.215/24      10.0.0.0        10.0.0.255      bridge1
  1   10.1.0.1/24        10.1.0.0        10.1.0.255      wlan1
[admin@Station] ip address> set [find interface=ether1 ] interface=bridge1
[admin@Station] ip address> print
  0   10.0.0.216/24      10.0.0.0        10.0.0.255      bridge1
  1   10.1.0.2/24        10.1.0.0        10.1.0.255      wlan1
What is the reason for doing it ? I didn't do it and my sistem is working perfekt the idea of the constructions is:
LAN1 - eth - ROS - wlan 5.x ~~~~~ wlan 5.x - ROS - eth - LAN2
Where LAN1 and LAN2 should see each other without any problem :slight_smile:.
Get from: http://www.mikrotik.com/docs/ros/2.8/howto/howto.content
Now the ip addresses are:
0 ;;; added by setup
10.33.124.20/25 10.33.124.0 10.33.124.127 Builtin
1 10.124.124.2/30 10.124.124.0 10.124.124.3 Senao
and on the other side:
10.33.124.10/25 10.33.124.0 10.33.124.127 Builtin
1 10.124.124.1/30 10.124.124.0 10.124.124.3 Senao
you ask about setting IP address for Bridge ?
you can as well configure it for one of the interfaces in the bridge.
Ok soo, the 5 step is unduly.
That was the questions - thanks.
I tried this out with 2.9rc7. After about an hour the bridge went crazy and started flooding the network with packets (brought the whole network down until I figured out what it was.) I removed the bridge and now it is back to normal.
I set it up exactly as in the how-to. (I am very new to Microtik)
rc = Release Candidate. It is not stable version. Use 2.8.x ot 2.9.x instead.
The IP address is for management purposes only.. Bridges operate at layer 2 and have no need or use for an IP address. The only reason for assigning the IP address to the bridge interface is to be able to remotely manage the device from all interfaces in the bridge. Whether your connecting from the WLAN interface or an ethernet interface.
If you only want to be able to access the router from the ether1 interface then the way you set it up is fine and suites your needs.
“There’s more than one way to skin a cat.”
