Just wanting to glean some ideas about setting up a wireless mesh network.
Currently we are looking to create a 5.8ghz network between 6 points (in a star shape)
5 of these points has a 2.4ghz card which we’re going to setup an encrypted network on.
The network needs to be transparently bridged.
The network has one central point that is just 5.8ghz and has line of sight to all the other points
one point has a Ethernet network, which although needs to be separated from the wireless network, will provide an internet link to the wirelessly connected clients.
See diagram below:
Just wondering if anyone could give me an idea on how I could transparently bridge these while using dynamic-wds for the 5.8ghz and keeping the same dhcp ranges for the 2.4ghz AP’s.
The only other issue we had is that some of the stations go off from time to time, is there anyway for the ap-bridge mode to be applied to all the 5ghz stations and allow a dynamic mesh?
So like I showed above with the five stations.. is there an way to get them to continue to link (dynamically preferably) if per-chance the middle one lost power?
The wonderful thing about using MT from my limited experience is that, the possiblities is only limited by our creativity and imagination.
I would address " stations go off from time to time" problem first b’cos I find this config to be most stable and easier to manage. Did you check stp/rstp on bridge?
Yes you could config. all 5Ghz as AP-bridge (wds) and they would associate with each other but I find this config. not as reliable as the previous. Maybe u could try to established static wds to only few selected AP-bridge instead of leaving all to dynamic.
I was referring to problems with the actual sites.
The power to different areas is sometimes cut, and therefore links are dropped. Hence if the center point lost power (which is actually being provided off a mobile phone tower.. the telco company was nice enough ) then the other sites need to be able to continue without issues.
The sites are all positioned in such a way that they can all see at least 2 other points… so a dynamic setup should cover a single outage, I’m just trying to make sure that this is fine and I’m not looking to do the impossible. (Don’t have much experience with the wds and mesh stuff sorry :-/ )
