Transparent Bridigng w/ SR9 and WDS
Has anyone been able to accomplish this using an AP with WDS enabled and a client in station-wds mode?
I can get the client device to connect using bridge mode on the SR9.. but Station-WDS does not work..
Should I be using bridge mode for CPE’s? What’s up with WDS on SR9s? I was testing with ROS devices v2.9.25 and newer.
Contact Support with attached support output files from both routers.
