Hello friends
I am using a language translator, because I do not speak English very well, I hope you can understand this post.
I require that a host (SIP SERVER) can have direct connection with the ISP, I will explain them immediately:
Network scenario
[ISP] 189.xxx.xxx.xxx/21 ---- [MK GATEWAY] 11.11.11.0/24 ---- 11.11.11.252 [MK LAN] 192.168.0.0/23 ---- 192.168.0.1 [SIP] SERVER]
The problem is that I receive daily attacks on port 5060 (SIP), and the SIP SERVER blocks my network 192.168.1.253 (GATEWAY) instead of blocking the IP of the attacker.
I have made a NAT rule for the port forwarding and I can communicate successfully from the INTERNET to the SIP SERVER.
How can I realize that the SIP SERVER can see the IP from the INTERNET attackers, and not block the IP of the GATEWAY?
I thank you very much if you can help me
I share my FIREWALL rules.}
Gateway Rules
/ip firewall address-list
add address=11.11.11.0/24 list=“LAN HMI”
add address=10.10.10.0/24 list=“LAN DHCP”
add address=11.11.11.0/24 list=DNS_Accept
add address=10.10.10.0/24 list=DNS_Accept
add address=8.8.8.8 comment=“Add DNS Server to this List” list=DNS_Accept
add address=8.8.4.4 comment=“Add DNS Server to this List” list=DNS_Accept
add address=208.67.222.222 comment=“Add DNS Server to this List” list=
DNS_Accept
add address=208.67.220.220 comment=“Add DNS Server to this List” list=
DNS_Accept
add action=accept chain=input comment=“Accept PINGS” disabled=yes protocol=
icmp
add action=accept chain=input comment=“Port SIP Open” dst-port=5060 protocol=
udp
add action=accept chain=forward comment=“Port SIP Open” dst-port=5060
protocol=udp
add action=add-src-to-address-list address-list=“0 IP SIP Request”
address-list-timeout=none-dynamic chain=forward comment=
“Port SIP Open LOG” dst-port=5060 protocol=udp
add action=accept chain=input comment=IN_CONN_Establecidas connection-state=
established
add action=accept chain=input comment=IN_CONN_Relacionadas connection-state=
related
add action=drop chain=input comment=“IN_CONN_Drop Invalidas”
connection-state=invalid
add action=accept chain=input comment=“IN_CONN_Acept DHCP” src-address=
10.10.10.0/24
add action=accept chain=input comment=“IN_CONN_Accept Router” src-address=
11.11.11.252
add action=jump chain=input comment=“Jump to DNS_DDoS Chain” jump-target=
DNS_DDoS
add action=accept chain=DNS_DDoS comment=“Make exceptions for DNS” port=53
protocol=udp src-address-list=DNS_Accept
dst-address-list=DNS_Accept port=53 protocol=udp
add action=add-src-to-address-list address-list=DNS_DDoS
address-list-timeout=none-dynamic chain=DNS_DDoS comment=
“Add DNS_DDoS Offenders to Blacklist” port=53 protocol=udp
src-address-list=!DNS_Accept
add action=drop chain=DNS_DDoS comment=“Drop DNS_DDoS Offenders”
src-address-list=DNS_DDoS
add action=return chain=DNS_DDoS comment=“Return from DNS_DDoS Chain”
add action=drop chain=input comment=“Drop External DNS” dst-port=53
in-interface=ether1-ISPMetrocarrier protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1-ISPMetrocarrier
protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether2-ISPMegacable
protocol=tcp
protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether3-ISPTelmex
protocol=tcp
protocol=udp
add action=add-src-to-address-list address-list=“port scanners”
address-list-timeout=2w chain=input comment="Port scanners to list "
log-prefix=Port_Scanner protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment=“NMAP FIN Stealth scan”
protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment=“SYN/FIN scan” protocol=tcp
tcp-flags=fin,syn
address-list-timeout=2w chain=input comment=“SYN/RST scan” protocol=tcp
tcp-flags=syn,rst
address-list-timeout=2w chain=input comment=“FIN/PSH/URG scan” protocol=
tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment=“ALL/ALL scan” protocol=tcp
tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment=“NMAP NULL scan” protocol=tcp
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“dropping port scanners” log-prefix=
PORTSCANNER src-address-list=“port scanners”
add action=add-src-to-address-list address-list=1-Knocking
address-list-timeout=20s chain=input comment="PortKnocking " dst-port=
2222 protocol=tcp
add action=add-src-to-address-list address-list=2-Knocking
address-list-timeout=10m chain=input dst-port=1111 protocol=tcp
src-address-list=1-Knocking
add action=add-src-to-address-list address-list=3SecureKnockingAccess
address-list-timeout=none-dynamic chain=input src-address-list=2-Knocking
add action=accept chain=input comment=“PortKnocking Accept” src-address-list=
2-Knocking
add action=drop chain=input comment=“Poxy To Internet” dst-port=8080
add action=drop chain=input dst-port=8080 in-interface=ether2-ISPMegacable
protocol=tcp
add action=drop chain=input dst-port=8080 in-interface=ether3-ISPTelmex
protocol=tcp
add action=drop chain=input comment=“FIltra ICMP Redirect” icmp-options=
5:0-255 protocol=icmp
add action=drop chain=input comment=“Filtro ataque SSH” connection-state=new
dst-port=22 protocol=tcp src-address-list=SSH_Rompepelotas
add action=add-src-to-address-list address-list=SSH_Rompepelotas
address-list-timeout=10m chain=input connection-state=new dst-port=22
protocol=tcp src-address-list=SSH_TercerIntento
add action=add-src-to-address-list address-list=SSH_TercerIntento
address-list-timeout=1m chain=input connection-state=new dst-port=22
protocol=tcp src-address-list=SSH_SegundoIntento
add action=add-src-to-address-list address-list=SSH_SegundoIntento
protocol=tcp src-address-list=SSH_PrimerIntento
add action=add-src-to-address-list address-list=SSH_PrimerIntento
protocol=tcp src-address-list=!SSH_PrimerIntento
add action=drop chain=input comment=“IN_CONN_Drop el resto”
add action=add-src-to-address-list address-list=ConnRemote_21
address-list-timeout=none-dynamic chain=forward disabled=yes dst-port=21
protocol=tcp
address-list-timeout=20s chain=forward comment=“PortKnocking " dst-port=
2222 protocol=tcp
address-list-timeout=1m chain=forward dst-port=1111 protocol=tcp
address-list-timeout=none-dynamic chain=forward src-address-list=
2-Knocking
add action=accept chain=forward comment=“PortKnocking Accept”
add action=fasttrack-connection chain=forward comment=FastTrack
add action=accept chain=forward comment=FWD_CONN_Establecidas
connection-state=established
add action=accept chain=forward comment=FWD_CONN_Relacionadas
connection-state=related
add action=drop chain=forward comment=FWD_CONN_Invalidas connection-state=
invalid
add action=accept chain=forward comment=“FWD_CONN_Lan DHCP” out-interface=
ether1-ISPMetrocarrier src-address=10.10.10.0/24 src-address-list=
“LAN DHCP”
add action=accept chain=forward comment=“FWD_CONN_Lan HMI” out-interface=
ether1-ISPMetrocarrier src-address=11.11.11.252
add action=drop chain=forward comment=“FWD_CONN_Drop Bogon Forward”
connection-nat-state=”" in-interface=ether1-ISPMetrocarrier log=yes
log-prefix=“Bogon Forward Drop” src-address-list=Bogon
connection-nat-state=“” in-interface=ether2-ISPMegacable log=yes
connection-nat-state=“” in-interface=ether3-ISPTelmex log=yes log-prefix=
ether2-ISPMegacable src-address=11.11.11.252
ether2-ISPMegacable src-address=10.10.10.0/24 src-address-list=“LAN DHCP”
add action=drop chain=forward comment=“Drop Internal DNS” dst-port=53
out-interface=!ether1-ISPMetrocarrier protocol=tcp
add action=drop chain=forward dst-port=53 out-interface=
!ether1-ISPMetrocarrier protocol=udp
add action=drop chain=forward dst-port=53 out-interface=!ether2-ISPMegacable
protocol=tcp
protocol=udp
add action=drop chain=forward comment=“Drop Anything Else”
add action=masquerade chain=srcnat comment=“ISP Out”
add action=redirect chain=dstnat comment=“DNS Redirection” dst-port=53
in-interface=!ether1-ISPMetrocarrier protocol=tcp
add action=redirect chain=dstnat dst-port=53 in-interface=
!ether2-ISPMegacable protocol=tcp
!ether2-ISPMegacable protocol=udp
add action=redirect chain=dstnat dst-port=53 in-interface=!ether3-ISPTelmex
protocol=tcp
protocol=udp
add action=dst-nat chain=dstnat comment=“Remote SIP Connection” dst-port=5060
in-interface=ether1-ISPMetrocarrier protocol=udp to-addresses=
11.11.11.252 to-ports=5060
LAN Rules
add address=10.0.0.0-10.0.13.252 list=“IP Hotspot”
add address=192.168.1.0/24 list=“IP Admon”
add address=10.10.10.0/24 list=“IP DHCP”
add address=10.0.0.0/20 list=DNS_Accept
add address=192.168.1.0/24 list=DNS_Accept
DNS_Accept
DNS_Accept
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=drop chain=input comment=“Drop Ping from Hotspot” protocol=icmp
src-address-list=“IP Hotspot”
add action=drop chain=forward comment=“Drop Ping from Hotspot to Gateway”
dst-address=11.11.11.253 protocol=icmp src-address-list=“IP Hotspot”
established
related
add action=drop chain=input comment=IN_CONN_Invalidas connection-state=
invalid
DNS_DDoS
add action=accept chain=input comment=“IN_CONN_Lan ADMON” disabled=yes
src-address-list=“IP Admon”
add action=accept chain=input comment=“IN_CONN_Lan DHCP” disabled=yes
src-address-list=“IP DHCP”
add action=accept chain=input comment=“IN_CONN_Lan HOTSPOT” disabled=yes
add action=drop chain=input comment=“IN_CONN_Drop Lan” connection-nat-state=
!dstnat disabled=yes
connection-nat-state=“” disabled=yes
connection-state=established,related disabled=yes
connection-state=established disabled=yes
connection-state=related disabled=yes
invalid disabled=yes
add action=accept chain=forward comment=“FWD_CONN_Lan ADMON” disabled=yes
add action=accept chain=forward comment=“FWD_CONN_Lan DHCP” disabled=yes
add action=accept chain=forward comment=“FWD_CONN_Lan HOTSPOT” disabled=yes
add action=drop chain=forward comment=“FWD_CONN_Drop Lan”
connection-nat-state=!dstnat disabled=yes
add action=drop chain=virus comment=“Drop Blaster Worm” dst-port=135-139
protocol=tcp
add action=drop chain=virus comment=“Drop Messenger Worm” dst-port=135-139
protocol=udp
add action=drop chain=virus comment=“Drop Blaster Worm” dst-port=445
protocol=tcp
protocol=udp
add action=drop chain=virus comment=________ dst-port=593 protocol=tcp
add action=drop chain=virus comment=“Drop MyDoom” dst-port=1080 protocol=tcp
add action=drop chain=virus comment=________ dst-port=1214 protocol=tcp
add action=drop chain=virus comment=“ndm requester” dst-port=1363 protocol=
tcp
add action=drop chain=virus comment=“ndm server” dst-port=1364 protocol=tcp
add action=drop chain=virus comment=“screen cast” dst-port=1368 protocol=tcp
add action=drop chain=virus comment=hromgrafx dst-port=1373 protocol=tcp
add action=drop chain=virus comment=cichlid dst-port=1377 protocol=tcp
add action=drop chain=virus comment=Worm dst-port=1433-1434 protocol=tcp
add action=drop chain=virus comment=“Bagle Virus” dst-port=2745 protocol=tcp
add action=drop chain=virus comment=“Drop Dumaru.Y” dst-port=2283 protocol=
tcp
add action=drop chain=virus comment=“Drop Beagle” dst-port=2535 protocol=tcp
add action=drop chain=virus comment=“Drop Beagle.C-K” dst-port=2745 protocol=
tcp
add action=drop chain=virus comment=“Drop MyDoom” dst-port=3127-3128
protocol=tcp
add action=drop chain=virus comment=“Drop Backdoor OptixPro” dst-port=3410
protocol=tcp
add action=drop chain=virus comment=Worm dst-port=4444 protocol=tcp
add action=drop chain=virus comment=Worm dst-port=4444 protocol=udp
add action=drop chain=virus comment=“Drop Sasser” dst-port=5554 protocol=tcp
add action=drop chain=virus comment=“Drop Beagle.B” dst-port=8866 protocol=
tcp
add action=drop chain=virus comment=“Drop Dabber.A-B” dst-port=9898 protocol=
tcp
add action=drop chain=virus comment=“Drop Dumaru.Y” dst-port=10000 protocol=
tcp
add action=drop chain=virus comment=“Drop MyDoom.B” dst-port=10080 protocol=
tcp
add action=drop chain=virus comment=“Drop NetBus” dst-port=12345 protocol=tcp
add action=drop chain=virus comment=“Drop Kuang2” dst-port=17300 protocol=tcp
add action=drop chain=virus comment=“Drop SubSeven” dst-port=27374 protocol=
tcp
add action=drop chain=virus comment=“Drop PhatBot, Agobot, Gaobot” dst-port=
65506 protocol=tcp
add action=jump chain=forward comment=“jump to the virus chain” jump-target=
virus
“Drop tries to reach not public addresses from LAN” dst-address-list=
not_in_internet in-interface=ether1-ISPMetrocarrier log=yes log-prefix=
!public_from_LAN out-interface=!ether1-ISPMetrocarrier
“Drop incoming packets that are not NATted” connection-nat-state=!dstnat
connection-state=new in-interface=ether1-ISPMetrocarrier log=yes
log-prefix=!NAT
“Drop incoming from internet which is not public IP” in-interface=
ether1-ISPMetrocarrier log=yes log-prefix=!public src-address-list=
not_in_internet
protocol=udp
protocol=tcp
protocol=udp
protocol=tcp
protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether11-Gateway
protocol=udp
protocol=tcp
protocol=tcp
protocol=tcp
add action=drop chain=input dst-port=8080 in-interface=ether11-Gateway
protocol=tcp
tcp-flags=fin,syn
tcp-flags=syn,rst
protocol=tcp
protocol=udp
add action=drop chain=forward dst-port=53 out-interface=!ether3-ISPTelmex
protocol=tcp
protocol=udp
add action=drop chain=forward dst-port=53 out-interface=!ether11-Gateway
protocol=tcp
protocol=udp
add action=drop chain=forward comment=“Block Admon a Hotspot” dst-address=
10.0.0.0/20 src-address=192.168.0.0/23
add action=drop chain=forward comment=“Block Hotspot a Admon” dst-address=
192.168.0.0/23 src-address=10.0.0.0/20
add action=drop chain=forward comment=“Block Hotspot a Hotspot” dst-address=
10.0.0.0/20 src-address=10.0.0.0/20
add action=drop chain=forward comment=“Block Hotspot a Gateway” dst-address=
11.11.11.0/24 src-address=10.0.0.0/20
add action=drop chain=forward comment=“Block Hotspot a DHCP” dst-address=
10.10.10.0/24 src-address=10.0.0.0/20
add action=drop chain=forward comment=“Block Hotspot a Telmex” dst-address=
192.168.11.0/24 src-address=10.0.0.0/20
add action=drop chain=forward comment=“Block Hotspot a Megacable”
dst-address=192.168.10.0/24 src-address=10.0.0.0/20
protocol=tcp
protocol=udp
add action=redirect chain=dstnat dst-port=53 in-interface=!ether11-Gateway
protocol=tcp
protocol=udp
in-interface=ether11-Gateway protocol=udp to-addresses=192.168.0.1
to-ports=5060
