Transparent L2 bridge via wireless P2P but no LOS
Hi wireles gurus :slight_smile:
I’d like to connect 2 locations via a PtP link (transparent bridge L2, no routing ). Since there is no LOS I’ll have to use 4 Dynadish.
switch1 - cable - Dyna1 - wireless - Dyna2 - cable - Dyna3 - wireless - Dyna4 - switch2
So is this a straightforward thing, meaning that id put the ethernet port and wifi interface on all 4 danydish in bridge and then connect each pair via a wds bridge ?
Or is there something I need to be careful about ?
Are there some special settings that differ in this scenario opposed to a direct P2P link (with just 2 Dynas)?
THX
Very straightforward! Use ap-bridge & station-bridge on the pairs.
