Transparent Layer 7 shaper config..
Hi guys, im trying to setup a transparent Layer 7 shaper based on the config here:
http://wiki.mikrotik.com/wiki/Basic_traffic_shaping_based_on_layer-7_protocols
ether 1 (wan) and ether 2 (Lan) are bridged.
I think i may be having issue with the mangle rules…
I have my queue tree rules setup like this:
Main in 8m 7m parent=global in
-priority1_in
—some stuff
-priority2_in
— some other stuff
Main out 2m 2m parent=global out
-priority1_out
— some stuff
-priority2_out
— some other stuff
I seem to be stuck with 2m both ways, it is not falling into the right category for download. its all upload.
I have tried running my mangles with the in and out interfaces as ether 1, bridge1, and also with no in or out interface specified. doesn’t seem to matter.
here is an example mangle the way i think it should be for my application:
/ip firewall mangle
add action=mark-packet chain=prerouting comment=100bao_p2p disabled=no
in-interface=bridge1 layer7-protocol=100bao new-packet-mark=100bao_p2p_in
passthrough=yes
add action=mark-packet chain=postrouting comment=“” disabled=no
layer7-protocol=100bao new-packet-mark=100bao_p2p_out out-interface=bridge1 \
What do you guys think? Is what im doing not possible in a bridge?
This guide here has similar rules, but is using simple queues instead of queue tree’s to actually throttle aggrigate data:
http://wiki.mikrotik.com/wiki/TransparentTrafficShaper
can i not use queue tree for this in bridge mode?
Using an exact copy of the guide here: http://wiki.mikrotik.com/wiki/Basic_traffic_shaping_based_on_layer-7_protocols with the two ethernet interfaces used in a bridge doesn’t work at all… it doesn’t throttle squat.
Here is my config, it sort of works, but it limits all traffic to the upload limit of 2meg for some reason.
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment=“” disabled=no forward-delay=15s l2mtu=1524 max-message-age=20s
mtu=1500 name=bridge1 priority=0x8000 protocol-mode=none
transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:53:BC:2D
master-port=none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:53:BC:2E
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:53:BC:2F
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:53:BC:30
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:53:BC:31
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
switch-all-ports=yes
/ip firewall layer7-protocol
add comment=“” name=edonkey regexp=“[1].?.?.?.?([\01\02\05\14
\15\16\18\19\1A\1B\1C !234568@ABCFGHIJKLMNOPQRSTUVWX[`\81\82\90\91\93\96
\97\98\99\9A\9B\9C\9E\A0\A1\A2\A3\A4]|Y…?[ -~]|\96…$)”
add comment=“” name=goboogy regexp=“|^get /getfilebyhash\.cgi\?|^
get /queue_register\.cgi\?|^get /getupdowninfo\.cgi\?”
add comment=“” name=soribada regexp=“^GETMP3\r
\nFilename|^\01.?.?.?(Q:\+|Q2:)|^\10[\14-\16]\10[\15-\17].?.?.?.?
add comment=“” name=rdp regexp=rdpdr.cliprdr.rdpsnd
add comment=“” name=gnutella regexp="^(gnd[\01\02]?.?.?\01|gnutella connect
/[012]\.[0-9]\r
\n|get /uri-res/n2r\?urn:sha1:|get /.user-agent: (gtk-gnutella|bearshar
e|mactella|gnucleus|gnotella|limewire|imesh)|get /.content-type: applicat
ion/x-gnutella-packets|giv [0-9]
:[0-9a-f]
/|queue [0-9a-f]
[1-9][0-9]?[
0-9]?\.[1-9][0-9]?[0-9]?\.[1-9][0-9]?[0-9]?\.[1-9][0-9]?[0-9]?:[
1-9][0-9]?[0-9]?[0-9]?|gnutella.content-type: application/x-gnutella|.
…?lime)"
add comment=“” name=cvs regexp=“^BEGIN (AUTH|VERIFICATION|GSSAPI) REQUEST
\n”
add comment=“” name=nbns regexp=“\01\10\01|\)\10\01\01|0\10\01”
add comment=“” name=shoutcast regexp=
"icy [1-5][0-9][0-9] [\t-\r -~]
(content-type:audio|icy-)"
add comment=“” name=dns regexp="^.?.?.?.?[\01\02].?.?.?.?.?.?[\01-?
][a-z0-9][\01-?a-z]
[\02-\06][a-z][a-z][fglmoprstuvz]?[aeop]?(um)?[\01
-\10\1C][\01\03\04\FF]"
add comment=“” name=quake-halflife regexp=“^\FF\FF\FF\FFget(info|challenge)”
add comment=“” name=poco regexp=“^\80\94
\n\01…\1F\9E”
add comment=“” name=ciscovpn regexp=“^\01\F4\01\F4”
add comment=“” name=x11 regexp=“[2].?\0B”
add comment=“” name=xboxlive regexp=“^X\80…\F3|^\06XN”
add comment=“” name=applejuice regexp=“^ajprot\r
\n”
add comment=“” name=zmaap regexp=“^\1B\D7;H[\01\02]\01?\01”
add comment=“” name=live365 regexp=membername.session.player
add comment=“” name=rlogin regexp=
[3][a-z0-9][a-z0-9]+/[1-9][0-9]?[0-9]?[0-9]?00”
add comment=“” name=http regexp="http/(0\.9|1\.0|1\.1) [1-5][0-9][0-9] [\t-
\r -~]
(connection:|content-type:|content-length:|date:)|post [\t-\r -~]
http/[01]\.[019]"
add comment=“” name=sip regexp=
“^(invite|register|cancel) sip[\t-\r -~]sip/[0-2]\.[0-9]"
add comment=“” name=pop3 regexp=“^(\+ok |-err )”
add comment=“” name=smb regexp=“\FFsmb[r%]”
add comment=“” name=quake1 regexp=“^\80\0C\01quake\03”
add comment=“” name=lpd regexp="^(\01[!-~]+|\02[!-~]+
\n.[\01\02\03][\01-
\n -~]
|[\03\04][!-~]+[\t-\r]+[a-z][\t-\r -~]|\05[!-~]+[\t-\r]+([a-z][!-~
[\t-\r]+[1-9][0-9]?[0-9]?|root[\t-\r]+[!-~]+).)
\n$"
add comment=“” name=mute regexp=
"^(Public|AES)Key: [0-9a-f]
\nEnd(Public|AES)Key
\n$”
add comment=“” name=ssh regexp=“^ssh-[12]\.[0-9]”
add comment=“” name=jabber regexp=
“<stream:stream[\t-\r ][ -~][\t-\r ]xmlns=['"]jabber"
add comment=“” name=bittorrent regexp=“^(\13bittorrent protocol|azver\01$|get
/scrape\?info_hash=)|d1:ad2:id20:|\08’7P\)[RP]”
add comment=“” name=ncp regexp="^(dmdt.
\01.(""|\11\11|uu)|tncp.33)"
add comment=“” name=tls regexp=
"^(.?.?\16\03.
\16\03|.?.?\01\03\01?.
\0B)”
add comment=“” name=directconnect regexp=“^(\$mynick |\$lock |\$key )”
add comment=“” name=netbios regexp=“\81.?.?.[A-P][A-P][A-P][A-P][A-P][A-P][A
-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][
A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P][A-P]
[A-P][A-P][A-P][A-P]”
add comment=“” name=tftp regexp=“^(\01|\02)[ -~](netascii|octet|mail)"
add comment=“” name=subspace regexp=“^\01…\11\10…\01$”
add comment=“” name=hotline regexp=“^…TRTPHOTL\01\02”
add comment=“” name=doom3 regexp=“^\FF\FFchallenge”
add comment=“” name=ftp regexp=“^220[\t-\r -~]ftp"
add comment=“” name=kugoo regexp=“^1..\8E”
add comment=“” name=tsp regexp=
[4]\01.?.?.?.?.?.?.?.?.?.?[ -~]+”
add comment=“” name=battlefield1942 regexp=“^\01\11\10\|\F8\02\10@\06”
add comment=“” name=ssdp regexp="^notify[\t-\r ]\
[\t-\r ]http/1\.1[\t-\r -~
]ssdp:(alive|byebye)|^m-search[\t-\r ]\[\t-\r ]http/1\.1[\t-\r -~]ssd
p:discover"
add comment=“” name=imap regexp="^(\
ok|a[0-9]+ noop)”
add comment=“” name=ares regexp=“^\03[]Z].?.?\05$”
add comment=“” name=fasttrack regexp="^get (/.download/[ -~]
|/.supernode[ -~]
|/.status[ -~]|/.network[ -~]|/.files|/.hash=[0-9a-f]/[ -~]) http/1.1|u
ser-agent: kazaa|x-kazaa(-username|-network|-ip|-supernodeip|-xferid|-xfer
uid|tag)|^give [0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9]?[0-9]?[0-9]?"
add comment=“” name=qq regexp=“^.?\02.+\03$”
add comment=“” name=100bao regexp=“^\01\01\05
\n”
add comment=“” name=aim regexp=
[\01\02].\03\0B|\\01.?.?.?.?\01)|flapon|toc_signon.0x"
add comment=“” name=unknown regexp=.
add comment=“” name=msn-filetransfer regexp=
“^(ver [ -~]msnftp\r
\nver msnftp\r
\nusr|method msnmsgr:)"
add comment=“” name=yahoo regexp=
"^(ymsg|ypns|yhoo).?.?.?.?.?.?.?[lwt].
\C0\80”
add comment=“” name=validcertssl regexp="^(.?.?\16\03.
\16\03|.?.?\01\03
\01?.\0B).(thawte|equifax secure|rsa data security, inc|verisign, inc|g
te cybertrust root|entrust\.net limited)”
add comment=“” name=ntp regexp=“^([\13\1B#\D3\DB\E3]|[\14\1C$]…?.?.?
.?.?.?.?.?.?[\C6-\FF])”
add comment=“” name=gnucleuslan regexp=
“gnuclear connect/[\t-\r -~]user-agent: gnucleus [\t-\r -~]lan:"
add comment=“” name=vnc regexp=“^rfb 00[1-9]\.00[0-9]
\n$”
add comment=“” name=bgp regexp=
“^\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF\FF..?\01[\03\04]”
add comment=“” name=tesla regexp=“\03\9A\89"111\.00 Beta |\E2<i\1E\1C\E9”
add comment=“” name=openft regexp=“x-openftalias: [-)(0-9a-z ~.]”
add comment=“” name=h323 regexp=
“^\03..?\08…?.?.?.?.?.?.?.?.?.?.?.?.?.?.?\05”
add comment=“” name=finger regexp=
"[5][a-z0-9\-_]+|login: [\t-\r -~]
Directory:”
add comment=“” name=ident regexp=“[6][0-9]?[0-9]?[0-9]?[0-9]?[\t-\r],[
\t-\r]
[1-9][0-9]?[0-9]?[0-9]?[0-9]?(\r
\n|[\r
\n])?$”
add comment=“” name=gkrellm regexp=“^gkrellm [23].[0-9].[0-9]
\n$”
add comment=“” name=hddtemp regexp=
“^\|/dev/[a-z][a-z][a-z]\|[0-9a-z]\|[0-9][0-9]\|[cfk]\|"
add comment=“” name=socks regexp="\05[\01-\08]
\05[\01-\08]?.\05[\01-\03][
\01\03].
\05[\01-\08]?[\01\03]”
add comment=“” name=biff regexp=“[7][a-z0-9]+@[1-9][0-9]+$”
add comment=“” name=dhcp regexp=“[8][\01- ]\06.c\82sc"
add comment=“” name=smtp regexp="^220[\t-\r -~]
(e?smtp|simple mail)”
add comment=“” name=ipp regexp=ipp://
add comment=“” name=msnmessenger regexp=“ver [0-9]+ msnp[1-9][0-9]? [\t-\r -~
]cvr0\r
\n$|usr 1 [!-~]+ [0-9. ]+\r
\n$|ans 1 [!-~]+ [0-9. ]+\r
\n$"
add comment=“” name=irc regexp="^(nick[\t-\r -~]user[\t-\r -~]:|user[\t-\r -
:[\02-\r -~]nick[\t-\r -~]\r
\n)”
add comment=“” name=gopher regexp=“[9][1-9,+tgi][\t-\r -~]\t[\t-\r -~]
\t[a-z0-9.]
\.[a-z][a-z].?.?\t[1-9]”
add comment=“” name=telnet regexp=“^\FF[\FB-\FE].\FF[\FB-\FE].\FF[\FB-\FE]”
add comment=“” name=snmp regexp=“^\02\01\04.+([\A0-\A3]\02[\01-\04].?.?.?.
?\02\01.?\02\01.?0|\A4\06.+@\04.?.?.?.?\02\01.?\02\01.?C)”
add comment=“” name=nntp regexp=
“^(20[01][\t-\r -~]AUTHINFO USER|20[01][\t-\r -~]news)"
add comment=“” name=aimwebcontent regexp=user-agent:aim/
add comment=“” name=rtsp regexp=“rtsp/1.0 200 ok”
add comment=“” name=skypeout regexp="^(\01.?.?.?.?.?.?.?.?\01|\02.?.
?.?.?.?.?.?.?\02|\03.?.?.?.?.?.?.?.?\03|\04.?.?.?.?.?.
?.?.?\04|\05.?.?.?.?.?.?.?.?\05|\06.?.?.?.?.?.?.?.?\06|
\07.?.?.?.?.?.?.?.?\07|\08.?.?.?.?.?.?.?.?\08|\t.?.?.?.
?.?.?.?.?\t|
\n.?.?.?.?.?.?.?.?
\n|\0B.?.?.?.?.?.?.?.?\0B|\0C.?.?.?.?.?.?.?.?\0C|\r.?.?.
?.?.?.?.?.?\r|\0E.?.?.?.?.?.?.?.?\0E|\0F.?.?.?.?.?.?.
?.?\0F|\10.?.?.?.?.?.?.?.?\10|\11.?.?.?.?.?.?.?.?\11|\12
.?.?.?.?.?.?.?.?\12|\13.?.?.?.?.?.?.?.?\13|\14.?.?.?.?
.?.?.?.?\14|\15.?.?.?.?.?.?.?.?\15|\16.?.?.?.?.?.?.?.?
\16|\17.?.?.?.?.?.?.?.?\17|\18.?.?.?.?.?.?.?.?\18|\19.?.
?.?.?.?.?.?.?\19|\1A.?.?.?.?.?.?.?.?\1A|\1B.?.?.?.?.?.
?.?.?\1B|\1C.?.?.?.?.?.?.?.?\1C|\1D.?.?.?.?.?.?.?.?\1D|
\1E.?.?.?.?.?.?.?.?\1E|\1F.?.?.?.?.?.?.?.?\1F| .?.?.?.
?.?/|0.?.?.?.?.?.?.?.?0|1.?.?.?.?.?.?.?.?1|2.?.?.?.?
.?.?.?.?2|3.?.?.?.?.?.?.?.?3|4.?.?.?.?.?.?.?.?4|5.?.
?.?.?.?.?.?.?5|6.?.?.?.?.?.?.?.?6|7.?.?.?.?.?.?.?.?
7|8.?.?.?.?.?.?.?.?8|9.?.?.?.?.?.?.?.?9|:.?.?.?.?.?.
?|@.?.?.?.?.?.?.?.?@|A.?.?.?.?.?.?.?.?A|B.?.?.?.?.?.
?.?.?B|C.?.?.?.?.?.?.?.?C|D.?.?.?.?.?.?.?.?D|E.?.?.?
.?.?.?.?.?E|F.?.?.?.?.?.?.?.?F|G.?.?.?.?.?.?.?.?G|H.
?.?.?.?.?.?.?.?H|I.?.?.?.?.?.?.?.?I|J.?.?.?.?.?.?.?
.?J|K.?.?.?.?.?.?.?.?K|L.?.?.?.?.?.?.?.?L|M.?.?.?.?.
?.?.?.?M|N.?.?.?.?.?.?.?.?N|O.?.?.?.?.?.?.?.?O|P.?.?
.?.?.?.?.?.?P|Q.?.?.?.?.?.?.?.?Q|R.?.?.?.?.?.?.?.?R|
S.?.?.?.?.?.?.?.?S|T.?.?.?.?.?.?.?.?T|U.?.?.?.?.?.?.
?.?U|V.?.?.?.?.?.?.?.?V|W.?.?.?.?.?.?.?.?W|X.?.?.?.?
.?.?.?.?X|Y.?.?.?.?.?.?.?.?Y|Z.?.?.?.?.?.?.?.?Z|\[.?
?.?.?.?.?.?.?.?`|a.?.?.?.?.?.?.?.?a|b.?.?.?.?.?.?.?
.?b|c.?.?.?.?.?.?.?.?c|d.?.?.?.?.?.?.?.?d|e.?.?.?.?.
?.?.?.?e|f.?.?.?.?.?.?.?.?f|g.?.?.?.?.?.?.?.?g|h.?.?
.?.?.?.?.?.?h|i.?.?.?.?.?.?.?.?i|j.?.?.?.?.?.?.?.?j|
k.?.?.?.?.?.?.?.?k|l.?.?.?.?.?.?.?.?l|m.?.?.?.?.?.?.
?.?m|n.?.?.?.?.?.?.?.?n|o.?.?.?.?.?.?.?.?o|p.?.?.?.?
.?.?.?.?p|q.?.?.?.?.?.?.?.?q|r.?.?.?.?.?.?.?.?r|s.?.
?.?.?.?.?.?.?s|t.?.?.?.?.?.?.?.?t|u.?.?.?.?.?.?.?.?
u|v.?.?.?.?.?.?.?.?v|w.?.?.?.?.?.?.?.?w|x.?.?.?.?.?.
?.?.?x|y.?.?.?.?.?.?.?.?y|z.?.?.?.?.?.?.?.?z|\{.?.?.
?.?\}|~.?.?.?.?.?.?.?.?~|\7F.?.?.?.?.?.?.?.?\7F|\80.?.
?.?.?.?.?.?.?\80|\81.?.?.?.?.?.?.?.?\81|\82.?.?.?.?.?.
?.?.?\82|\83.?.?.?.?.?.?.?.?\83|\84.?.?.?.?.?.?.?.?\84|
\85.?.?.?.?.?.?.?.?\85|\86.?.?.?.?.?.?.?.?\86|\87.?.?.?
.?.?.?.?.?\87|\88.?.?.?.?.?.?.?.?\88|\89.?.?.?.?.?.?.?
.?\89|\8A.?.?.?.?.?.?.?.?\8A|\8B.?.?.?.?.?.?.?.?\8B|\8C.
?.?.?.?.?.?.?.?\8C|\8D.?.?.?.?.?.?.?.?\8D|\8E.?.?.?.?.
?.?.?.?\8E|\8F.?.?.?.?.?.?.?.?\8F|\90.?.?.?.?.?.?.?.?
\90|\91.?.?.?.?.?.?.?.?\91|\92.?.?.?.?.?.?.?.?\92|\93.?.
?.?.?.?.?.?.?\93|\94.?.?.?.?.?.?.?.?\94|\95.?.?.?.?.?.
?.?.?\95|\96.?.?.?.?.?.?.?.?\96|\97.?.?.?.?.?.?.?.?\97|
\98.?.?.?.?.?.?.?.?\98|\99.?.?.?.?.?.?.?.?\99|\9A.?.?.?
.?.?.?.?.?\9A|\9B.?.?.?.?.?.?.?.?\9B|\9C.?.?.?.?.?.?.?
.?\9C|\9D.?.?.?.?.?.?.?.?\9D|\9E.?.?.?.?.?.?.?.?\9E|\9F.
?.?.?.?.?.?.?.?\9F|\A0.?.?.?.?.?.?.?.?\A0|\A1.?.?.?.?.
?.?.?.?\A1|\A2.?.?.?.?.?.?.?.?\A2|\A3.?.?.?.?.?.?.?.?
\A3|\A4.?.?.?.?.?.?.?.?\A4|\A5.?.?.?.?.?.?.?.?\A5|\A6.?.
?.?.?.?.?.?.?\A6|\A7.?.?.?.?.?.?.?.?\A7|\A8.?.?.?.?.?.
?.?.?\A8|\A9.?.?.?.?.?.?.?.?\A9|\AA.?.?.?.?.?.?.?.?\AA|
\AB.?.?.?.?.?.?.?.?\AB|\AC.?.?.?.?.?.?.?.?\AC|\AD.?.?.?
.?.?.?.?.?\AD|\AE.?.?.?.?.?.?.?.?\AE|\AF.?.?.?.?.?.?.?
.?\AF|\B0.?.?.?.?.?.?.?.?\B0|\B1.?.?.?.?.?.?.?.?\B1|\B2.
?.?.?.?.?.?.?.?\B2|\B3.?.?.?.?.?.?.?.?\B3|\B4.?.?.?.?.
?.?.?.?\B4|\B5.?.?.?.?.?.?.?.?\B5|\B6.?.?.?.?.?.?.?.?
\B6|\B7.?.?.?.?.?.?.?.?\B7|\B8.?.?.?.?.?.?.?.?\B8|\B9.?.
?.?.?.?.?.?.?\B9|\BA.?.?.?.?.?.?.?.?\BA|\BB.?.?.?.?.?.
?.?.?\BB|\BC.?.?.?.?.?.?.?.?\BC|\BD.?.?.?.?.?.?.?.?\BD|
\BE.?.?.?.?.?.?.?.?\BE|\BF.?.?.?.?.?.?.?.?\BF|\C0.?.?.?
.?.?.?.?.?\C0|\C1.?.?.?.?.?.?.?.?\C1|\C2.?.?.?.?.?.?.?
.?\C2|\C3.?.?.?.?.?.?.?.?\C3|\C4.?.?.?.?.?.?.?.?\C4|\C5.
?.?.?.?.?.?.?.?\C5|\C6.?.?.?.?.?.?.?.?\C6|\C7.?.?.?.?.
?.?.?.?\C7|\C8.?.?.?.?.?.?.?.?\C8|\C9.?.?.?.?.?.?.?.?
\C9|\CA.?.?.?.?.?.?.?.?\CA|\CB.?.?.?.?.?.?.?.?\CB|\CC.?.
?.?.?.?.?.?.?\CC|\CD.?.?.?.?.?.?.?.?\CD|\CE.?.?.?.?.?.
?.?.?\CE|\CF.?.?.?.?.?.?.?.?\CF|\D0.?.?.?.?.?.?.?.?\D0|
\D1.?.?.?.?.?.?.?.?\D1|\D2.?.?.?.?.?.?.?.?\D2|\D3.?.?.?
.?.?.?.?.?\D3|\D4.?.?.?.?.?.?.?.?\D4|\D5.?.?.?.?.?.?.?
.?\D5|\D6.?.?.?.?.?.?.?.?\D6|\D7.?.?.?.?.?.?.?.?\D7|\D8.
?.?.?.?.?.?.?.?\D8|\D9.?.?.?.?.?.?.?.?\D9|\DA.?.?.?.?.
?.?.?.?\DA|\DB.?.?.?.?.?.?.?.?\DB|\DC.?.?.?.?.?.?.?.?
\DC|\DD.?.?.?.?.?.?.?.?\DD|\DE.?.?.?.?.?.?.?.?\DE|\DF.?.
?.?.?.?.?.?.?\DF|\E0.?.?.?.?.?.?.?.?\E0|\E1.?.?.?.?.?.
?.?.?\E1|\E2.?.?.?.?.?.?.?.?\E2|\E3.?.?.?.?.?.?.?.?\E3|
\E4.?.?.?.?.?.?.?.?\E4|\E5.?.?.?.?.?.?.?.?\E5|\E6.?.?.?
.?.?.?.?.?\E6|\E7.?.?.?.?.?.?.?.?\E7|\E8.?.?.?.?.?.?.?
.?\E8|\E9.?.?.?.?.?.?.?.?\E9|\EA.?.?.?.?.?.?.?.?\EA|\EB.
?.?.?.?.?.?.?.?\EB|\EC.?.?.?.?.?.?.?.?\EC|\ED.?.?.?.?.
?.?.?.?\ED|\EE.?.?.?.?.?.?.?.?\EE|\EF.?.?.?.?.?.?.?.?
\EF|\F0.?.?.?.?.?.?.?.?\F0|\F1.?.?.?.?.?.?.?.?\F1|\F2.?.
?.?.?.?.?.?.?\F2|\F3.?.?.?.?.?.?.?.?\F3|\F4.?.?.?.?.?.
?.?.?\F4|\F5.?.?.?.?.?.?.?.?\F5|\F6.?.?.?.?.?.?.?.?\F6|
\F7.?.?.?.?.?.?.?.?\F7|\F8.?.?.?.?.?.?.?.?\F8|\F9.?.?.?
.?.?.?.?.?\F9|\FA.?.?.?.?.?.?.?.?\FA|\FB.?.?.?.?.?.?.?
.?\FB|\FC.?.?.?.?.?.?.?.?\FC|\FD.?.?.?.?.?.?.?.?\FD|\FE.
?.?.?.?.?.?.?.?\FE|\FF.?.?.?.?.?.?.?.?\FF)”
add comment=“” name=skypetoskype regexp=“^..\02…”
add comment=“” name=counterstrike-source regexp=
“^\FF\FF\FF\FF.cstrikeCounter-Strike"
add comment=“” name=halflife2-deathmatch regexp=
"^\FF\FF\FF\FF.hl2mpDeathmatch"
add comment=“” name=freenet regexp=“^\01[\08\t][\03\04]”
add comment=“” name=battlefield2 regexp=“^(\11 \01…?\11|\FE\FD.?.?.?.?.
?.?(\14\01\06|\FF\FF\FF))|[]\01].?battlefield2”
add comment=“” name=napster regexp=“^(.[\02\06][!-~]+ [!-~]+ [0-9][0-9]?[0-9]
?[0-9]?[0-9]? "[\t-\r -~]+" ([0-9]|10)|1(send|get)[!-~]+ "[\t-\r -~]
add comment=“” name=soulseek regexp=
“^(\05..?|.\01.[ -~]+\01F..?.?.?.?.?.?.?)$”
add comment=“” name=xunlei regexp=“[10]…?.?.?(reg|get|query)”
add comment=“” name=ssl regexp=
"^(.?.?\16\03.
\0B)”
add comment=“” name=citrix regexp=“2&\85\92X”
add comment=“” name=whois regexp=“[11]+\r
\n$”
add comment=“” name=dayofdefeat-source regexp=
“^\FF\FF\FF\FF.dodDay of Defeat"
add comment=“” name=teamspeak regexp=“^\F4\BE\03.teamspeak"
add comment=“” name=worldofwarcraft regexp=“^\06\EC\01”
add comment=“” name=ventrilo regexp=“^..?v\$\CF”
add comment=“” name=http-rtsp regexp="^(get[\t-\r -~]
Accept: application/x-r
tsp-tunnelled|http/(0\.9|1\.0|1\.1) [1-5][0-9][0-9] [\t-\r -~]a=contro
l:rtsp://)"
add comment=“” name=thecircle regexp=
“^t\03ni.?[\01-\06]?t[\01-\05]s[
\n\0B](glob|who are you$|query data)”
add comment=“” name=uucp regexp=“^\10here=”
add comment=“” name=pcanywhere regexp=“^(nq|st)$”
add comment=“” name=subversion regexp=“^\( success \( 1 2 \(”
add comment=“” name=imesh regexp="^(post[\t-\r -~]
…|4\80?\r?\FC\FF\04|get[\t-
\r -~]Host: imsh\.download-prod\.musicnet\.com|\02(\01|\02)\83.?.?.
.?\02(\01|\02)\83)"
add comment=“” name=cimd regexp="\02[0-4][0-9]:[0-9]+.
\03$”
add comment=“” name=mohaa regexp=“^\FF\FF\FF\FFgetstatus
\n”
add comment=“” name=stun regexp=“[12]…?$”
add comment=“” name=tor regexp=TOR1.
add comment=”" name=radmin regexp=“^\01\01(\08\08|\1B\1B)$”
add comment=“” name=unset regexp=.
add comment=“” name=chikka regexp=“^CTPv1.[123] Kamusta.\r
\n$"
add comment=“” name=replaytv-ivs regexp="^(get /ivs-IVSGetFileChunk|http/(0\.
#####REPLAY_CHUNK_START#####)”
add comment=“” name=armagetron regexp=YCLC_E|CYEL
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment=“” disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment=“” name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment=“” name=default-encryption
only-one=default use-compression=default use-encryption=yes
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0
max-limit=6M name=Main_in parent=global-total priority=1
max-limit=2M name=Main_out parent=global-out priority=1
max-limit=0 name=Priority1_in parent=Main_in priority=1
max-limit=0 name=Priority2_in parent=Main_in priority=2
max-limit=0 name=Priority3_in parent=Main_in priority=3
max-limit=0 name=Priority4_in parent=Main_in priority=4
max-limit=0 name=Priority5_in parent=Main_in priority=5
max-limit=0 name=Priority6_in parent=Main_in priority=6
max-limit=0 name=Priority7_in parent=Main_in priority=7
max-limit=0 name=Priority8_in parent=Main_in priority=8
max-limit=0 name=Priority1_out parent=Main_out priority=1
max-limit=0 name=Priority2_out parent=Main_out priority=2
max-limit=0 name=Priority3_out parent=Main_out priority=3
max-limit=0 name=Priority4_out parent=Main_out priority=4
max-limit=0 name=Priority5_out parent=Main_out priority=5
max-limit=0 name=Priority6_out parent=Main_out priority=6
max-limit=0 name=Priority7_out parent=Main_out priority=7
max-limit=0 name=Priority8_out parent=Main_out priority=8
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=4
max-limit=6M name=Main_in parent=global-in priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1M
max-limit=0 name=remaining_in packet-mark=remaining_in parent=
Priority8_in priority=1 queue=default
max-limit=0 name=remaining_out packet-mark=remaining_out parent=
Priority8_out priority=1 queue=default
max-limit=0 name=100bao_p2p_in packet-mark=100bao_p2p_in parent=
Priority7_in priority=1 queue=default
max-limit=0 name=aim_mesanger_in packet-mark=aim_mesanger_in parent=
Priority6_in priority=1 queue=default
max-limit=0 name=aim_mesenger_web_in packet-mark=aim_mesenger_web_in
parent=Priority6_in priority=1 queue=default
max-limit=0 name=applejuice_in packet-mark=applejuice_in parent=
max-limit=0 name=ares_p2p_in packet-mark=ares_p2p_in parent=Priority7_in
max-limit=0 name=http_in packet-mark=http_in parent=Priority2_in
max-limit=0 name=bittorent_in packet-mark=bittorent_in parent=
max-limit=0 name=dhcp_in packet-mark=dhcp_in parent=Priority2_in
max-limit=0 name=DC_p2p_in packet-mark=DC_p2p_in parent=Priority7_in
max-limit=0 name=DNS_in packet-mark=DNS_in parent=Priority1_in priority=1
queue=default
max-limit=0 name=edonkey_p2p_in packet-mark=edonkey_p2p_in parent=
max-limit=0 name=fasttrack_p2p_in packet-mark=fasttrack_p2p_in parent=
max-limit=0 name=ftp_in packet-mark=ftp_in parent=Priority5_in priority=1
queue=default
max-limit=0 name=gnu_p2p_in packet-mark=gnu_p2p_in parent=Priority7_in
max-limit=0 name=gnutella_p2p_in packet-mark=gnutella_p2p_in parent=
max-limit=0 name=gobogy_p2p_in packet-mark=gobogy_p2p_in parent=
max-limit=0 name=h323_voiceoverip_in packet-mark=h323_voiceoverip_in
parent=Priority4_in priority=1 queue=default
max-limit=0 name=httprtsp_in packet-mark=httprtsp_in parent=Priority5_in
max-limit=0 name=ident_in packet-mark=ident_in parent=Priority2_in
max-limit=0 name=imap_in packet-mark=imap_in parent=Priority2_in
max-limit=0 name=imesh_p2p_in packet-mark=imesh_p2p_in parent=
max-limit=0 name=irc_in packet-mark=irc_in parent=Priority5_in priority=1
queue=default
max-limit=0 name=msnfile_in packet-mark=msnfile_in parent=Priority6_in
max-limit=0 name=mute_p2p_in packet-mark=mute_p2p_in parent=Priority7_in
max-limit=0 name=napster_in packet-mark=napster_in parent=Priority7_in
max-limit=0 name=netbios_in packet-mark=netbios_in parent=Priority2_in
max-limit=0 name=nntp_in packet-mark=nntp_in parent=Priority2_in
max-limit=0 name=radmin_in packet-mark=radmin_in parent=Priority4_in
max-limit=0 name=ntp_in packet-mark=ntp_in parent=Priority2_in priority=1
queue=default
max-limit=0 name=rdp_in packet-mark=rdp_in parent=Priority4_in priority=1
queue=default
max-limit=0 name=rtsp_in packet-mark=rtsp_in parent=Priority6_in
max-limit=0 name=sip_in packet-mark=sip_in parent=Priority4_in priority=1
queue=default
max-limit=0 name=skypeout_in packet-mark=skypeout_in parent=Priority5_in
max-limit=0 name=skype2skype_in packet-mark=skype2skype_in parent=
Priority5_in priority=1 queue=default
max-limit=0 name=pop3_in packet-mark=pop3_in parent=Priority5_in
max-limit=0 name=smtp_in packet-mark=smtp_in parent=Priority2_in
max-limit=0 name=snmp_in packet-mark=snmp_in parent=Priority2_in
max-limit=0 name=soulsek_in packet-mark=soulsek_in parent=Priority7_in
max-limit=0 name=ssh_in packet-mark=ssh_in parent=Priority3_in priority=1
queue=default
max-limit=0 name=ssl_in packet-mark=ssl_in parent=Priority2_in priority=1
queue=default
max-limit=0 name=vnc_in packet-mark=vnc_in parent=Priority4_in priority=1
queue=default
max-limit=0 name=teamspeak_in packet-mark=teamspeak_in parent=
max-limit=0 name=100bao_p2p_out packet-mark=100bao_p2p_out parent=
Priority7_out priority=1 queue=default
max-limit=0 name=aim_mesanger_out packet-mark=aim_mesanger_out parent=
Priority6_out priority=1 queue=default
max-limit=0 name=aim_mesenger_web_out packet-mark=aim_mesenger_web_out
parent=Priority7_out priority=1 queue=default
max-limit=0 name=ares_p2p_out packet-mark=ares_p2p_out parent=
max-limit=0 name=bgp_routing_out packet-mark=bgp_routing_out parent=
Priority2_out priority=1 queue=default
max-limit=0 name=bittorent_out packet-mark=bittorent_out parent=
max-limit=0 name=dhcp_out packet-mark=dhcp_out parent=Priority2_out
max-limit=0 name=DC_p2p_out packet-mark=DC_p2p_out parent=Priority7_out
max-limit=0 name=DNS_out packet-mark=DNS_out parent=Priority1_out
max-limit=0 name=edonkey_p2p_out packet-mark=edonkey_p2p_out parent=
max-limit=0 name=fasttrack_p2p_out packet-mark=fasttrack_p2p_out parent=
max-limit=0 name=ftp_out packet-mark=ftp_out parent=Priority5_out
max-limit=0 name=gnu_p2p_out packet-mark=gnu_p2p_out parent=Priority7_out
max-limit=0 name=gnutella_p2p_out packet-mark=gnutella_p2p_out parent=
max-limit=0 name=gobogy_p2p_out packet-mark=gobogy_p2p_out parent=
max-limit=0 name=h323_voiceoverip_out packet-mark=h323_voiceoverip_out
parent=Priority4_out priority=1 queue=default
max-limit=0 name=httprtsp_out packet-mark=httprtsp_out parent=
Priority5_out priority=1 queue=default
max-limit=0 name=http_out packet-mark=http_out parent=Priority3_out
max-limit=0 name=ident_out packet-mark=ident_out parent=Priority2_out
max-limit=0 name=imap_out packet-mark=imap_out parent=Priority2_out
max-limit=0 name=imesh_p2p_out packet-mark=imesh_p2p_out parent=
max-limit=0 name=irc_out packet-mark=irc_out parent=Priority4_out
max-limit=0 name=koogo_out packet-mark=koogo_out parent=Priority7_out
max-limit=0 name=msnfile_out packet-mark=msnfile_out parent=Priority6_out
max-limit=0 name=msn_out packet-mark=msn_out parent=Priority5_out
max-limit=0 name=mute_p2p_out packet-mark=mute_p2p_out parent=
max-limit=0 name=napster_out packet-mark=napster_out parent=Priority7_out
max-limit=0 name=netbios_out packet-mark=netbios_out parent=Priority2_out
max-limit=0 name=nntp_out packet-mark=nntp_out parent=Priority2_out
max-limit=0 name=ntp_out packet-mark=ntp_out parent=Priority2_out
max-limit=0 name=radmin_out packet-mark=radmin_out parent=Priority4_out
max-limit=0 name=rdp_out packet-mark=rdp_out parent=Priority4_out
max-limit=0 name=rtsp_out packet-mark=rtsp_out parent=Priority5_out
max-limit=0 name=sip_out packet-mark=sip_out parent=Priority4_out
max-limit=0 name=skypeout_out packet-mark=skypeout_out parent=
max-limit=0 name=skype2skype_out packet-mark=skype2skype_out parent=
max-limit=0 name=pop3_out packet-mark=pop3_out parent=Priority4_out
max-limit=0 name=smtp_out packet-mark=smtp_out parent=Priority2_out
max-limit=0 name=snmp_out packet-mark=snmp_out parent=Priority2_out
max-limit=0 name=soulsek_out packet-mark=soulsek_out parent=Priority7_out
max-limit=0 name=ssh_out packet-mark=ssh_out parent=Priority3_out
max-limit=0 name=ssl_out packet-mark=ssl_out parent=Priority2_out
max-limit=0 name=vnc_out packet-mark=vnc_out parent=Priority5_out
max-limit=0 name=teamspeak_out packet-mark=teamspeak_out parent=
max-limit=0 name=applejuice_out packet-mark=applejuice_out parent=
max-limit=0 name=msn_in packet-mark=msn_in parent=Priority5_in priority=1
queue=default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment=“” disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set default comment=“” disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment=“” disabled=no instance=default name=
backbone type=default
/snmp
set contact=“” enabled=no engine-boots=0 engine-id=“” location=“”
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
add comment=“” name=read policy=“local,telnet,ssh,reboot,read,test,winbox,pass
word,web,sniff,sensitive,!ftp,!write,!policy”
add comment=“” name=write policy=“local,telnet,ssh,reboot,read,write,test,winb
ox,password,web,sniff,sensitive,!ftp,!policy”
add comment=“” name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy
,test,winbox,password,web,sniff,sensitive”
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto
horizon=none interface=ether2 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=
0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes
use-ip-firewall-for-vlan=yes
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:3C:68:F4:CA:F1
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=139.142.167.151/32 broadcast=139.142.167.151 comment=“” disabled=
no interface=ether3 network=139.142.167.151
/ip dhcp-client
add add-default-route=yes comment=“” default-route-distance=0 disabled=yes
interface=ether3 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 servers=192.168.8.1,4.2.2.3
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall mangle
passthrough=yes
bridge1 passthrough=yes
add action=mark-packet chain=prerouting comment=“aim mesenger” disabled=no
in-interface=bridge1 layer7-protocol=aim new-packet-mark=aim_mesanger_in
passthrough=yes
layer7-protocol=aim new-packet-mark=aim_mesanger_out out-interface=
add action=mark-packet chain=prerouting comment=aim_messenger_web disabled=no
in-interface=bridge1 layer7-protocol=aimwebcontent new-packet-mark=
aim_mesenger_web_in passthrough=yes
layer7-protocol=aimwebcontent new-packet-mark=aim_mesenger_web_out
out-interface=bridge1 passthrough=yes
add action=mark-packet chain=prerouting comment=applejuice_p2p disabled=no
in-interface=bridge1 layer7-protocol=applejuice new-packet-mark=
applejuice_in passthrough=yes
layer7-protocol=applejuice new-packet-mark=applejuice_out out-interface=
add action=mark-packet chain=prerouting comment=ares_p2p disabled=no
in-interface=bridge1 layer7-protocol=ares new-packet-mark=ares_p2p_in
passthrough=yes
layer7-protocol=ares new-packet-mark=ares_p2p_out out-interface=bridge1
passthrough=yes
add action=mark-packet chain=prerouting comment=bgp_routing disabled=no
in-interface=bridge1 layer7-protocol=bgp new-packet-mark=bgp_routing_in
passthrough=yes
layer7-protocol=bgp new-packet-mark=bgp_routing_out out-interface=bridge1
passthrough=yes
add action=mark-packet chain=prerouting comment=bittorent_p2p disabled=no
in-interface=bridge1 layer7-protocol=bittorrent new-packet-mark=
bittorent_in passthrough=yes
layer7-protocol=bittorrent new-packet-mark=bittorent_out out-interface=
add action=mark-packet chain=prerouting comment=dhcp disabled=no
in-interface=bridge1 layer7-protocol=dhcp new-packet-mark=dhcp_in
passthrough=yes
layer7-protocol=dhcp new-packet-mark=dhcp_out out-interface=bridge1
passthrough=yes
“Direct Connect - P2P filesharing " disabled=no in-interface=bridge1
layer7-protocol=directconnect new-packet-mark=DC_p2p_in passthrough=yes
add action=mark-packet chain=postrouting comment=”" disabled=no
layer7-protocol=directconnect new-packet-mark=DC_p2p_out out-interface=
add action=mark-packet chain=prerouting comment=“DNS - Domain Name System "
disabled=no in-interface=bridge1 layer7-protocol=dns new-packet-mark=
DNS_in passthrough=yes
layer7-protocol=dns new-packet-mark=DNS_out out-interface=bridge1
passthrough=yes
“eDonkey2000 - P2P filesharing " disabled=no in-interface=bridge1
layer7-protocol=edonkey new-packet-mark=edonkey_p2p_in passthrough=yes
layer7-protocol=edonkey new-packet-mark=edonkey_p2p_out out-interface=
“FastTrack - P2P filesharing (Kazaa, Morpheus, iMesh, Grokster, etc)”
disabled=no in-interface=bridge1 layer7-protocol=fasttrack
new-packet-mark=fasttrack_p2p_in passthrough=yes
layer7-protocol=fasttrack new-packet-mark=fasttrack_p2p_out
“FTP - File Transfer Protocol " disabled=no in-interface=bridge1
layer7-protocol=ftp new-packet-mark=ftp_in passthrough=yes
layer7-protocol=ftp new-packet-mark=ftp_out out-interface=bridge1
passthrough=yes
add action=mark-packet chain=prerouting comment=“GnucleusLAN - LAN-only P2P "
disabled=no in-interface=bridge1 layer7-protocol=gnucleuslan
new-packet-mark=gnu_p2p_in passthrough=yes
layer7-protocol=gnucleuslan new-packet-mark=gnu_p2p_out out-interface=
add action=mark-packet chain=prerouting comment=“Gnutella - P2P filesharing”
disabled=no in-interface=bridge1 layer7-protocol=gnutella
new-packet-mark=gnutella_p2p_in passthrough=yes
layer7-protocol=gnutella new-packet-mark=gnutella_p2p_out out-interface=
“GoBoogy - a Korean P2P protocol” disabled=no in-interface=bridge1
layer7-protocol=goboogy new-packet-mark=gobogy_p2p_in passthrough=yes
layer7-protocol=goboogy new-packet-mark=gobogy_p2p_out out-interface=
add action=mark-packet chain=prerouting comment=“H.323 - Voice over IP”
disabled=no in-interface=bridge1 layer7-protocol=h323 new-packet-mark=
h323_voiceoverip_in passthrough=yes
layer7-protocol=h323 new-packet-mark=h323_voiceoverip_out out-interface=
add action=mark-packet chain=prerouting comment=“RTSP tunneled within HTTP”
disabled=no in-interface=bridge1 layer7-protocol=http-rtsp
new-packet-mark=httprtsp_in passthrough=yes
layer7-protocol=http-rtsp new-packet-mark=httprtsp_out out-interface=
“www HyperText Transfer Protocol " disabled=no in-interface=bridge1
layer7-protocol=http new-packet-mark=http_in passthrough=yes
layer7-protocol=http new-packet-mark=http_out out-interface=bridge1
passthrough=yes
“Ident - Identification Protocol - RFC 1413” disabled=no in-interface=
bridge1 layer7-protocol=ident new-packet-mark=ident_in passthrough=yes
layer7-protocol=ident new-packet-mark=ident_out out-interface=bridge1
passthrough=yes
“IMAP - Internet Message Access Protocol (A common e-mail protocol)”
disabled=no in-interface=bridge1 layer7-protocol=imap new-packet-mark=
imap_in passthrough=yes
layer7-protocol=imap new-packet-mark=imap_out out-interface=bridge1
passthrough=yes
“iMesh - the native protocol of iMesh, a P2P application " disabled=no
in-interface=bridge1 layer7-protocol=imesh new-packet-mark=imesh_p2p_in
passthrough=yes
layer7-protocol=imesh new-packet-mark=imesh_p2p_out out-interface=bridge1
passthrough=yes
add action=mark-packet chain=prerouting comment=“IRC - Internet Relay Chat”
disabled=no in-interface=bridge1 layer7-protocol=irc new-packet-mark=
irc_in passthrough=yes
layer7-protocol=irc new-packet-mark=irc_out out-interface=bridge1
passthrough=yes
“KuGoo - a Chinese P2P program " disabled=no in-interface=bridge1
layer7-protocol=kugoo new-packet-mark=koogo_in passthrough=yes
layer7-protocol=kugoo new-packet-mark=koogo_out out-interface=bridge1
passthrough=yes
“MSN (Micosoft Network) Messenger file transfers " disabled=no
in-interface=bridge1 layer7-protocol=msn-filetransfer new-packet-mark=
msnfile_in passthrough=yes
layer7-protocol=msn-filetransfer new-packet-mark=msnfile_out
add action=mark-packet chain=prerouting comment=“MSN Messenger " disabled=no
in-interface=bridge1 layer7-protocol=msnmessenger new-packet-mark=msn_in
passthrough=yes
layer7-protocol=msnmessenger new-packet-mark=msn_out out-interface=
add action=mark-packet chain=prerouting comment=“MUTE - P2P filesharing "
disabled=no in-interface=bridge1 layer7-protocol=mute new-packet-mark=
mute_p2p_in passthrough=yes
layer7-protocol=mute new-packet-mark=mute_p2p_out out-interface=bridge1
passthrough=yes
add action=mark-packet chain=prerouting comment=“Napster - P2P filesharing”
disabled=no in-interface=bridge1 layer7-protocol=napster new-packet-mark=
napster_in passthrough=yes
layer7-protocol=napster new-packet-mark=napster_out out-interface=bridge1
passthrough=yes
“NetBIOS - Network Basic Input Output System” disabled=no in-interface=
bridge1 layer7-protocol=netbios new-packet-mark=netbios_in passthrough=
yes
layer7-protocol=netbios new-packet-mark=netbios_out out-interface=bridge1
passthrough=yes
“NNTP - Network News Transfer Protocol " disabled=no in-interface=bridge1
layer7-protocol=nntp new-packet-mark=nntp_in passthrough=yes
layer7-protocol=nntp new-packet-mark=nntp_out out-interface=bridge1
passthrough=yes
“SNTP - (Simple) Network Time Protocol " disabled=no in-interface=bridge1
layer7-protocol=ntp new-packet-mark=ntp_in passthrough=yes
layer7-protocol=ntp new-packet-mark=ntp_out out-interface=bridge1
passthrough=yes
“Remote Administrator - remote desktop for MS Windows” disabled=no
in-interface=bridge1 layer7-protocol=radmin new-packet-mark=radmin_in
passthrough=yes
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set from=<> password=“” server=0.0.0.0:25 username=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 memory-scroll=no only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
  1. \C5\D4\E3-\E5 ↩︎
  2. lb ↩︎
  3. a-z ↩︎
  4. \01-\13\16-$ ↩︎
  5. a-z ↩︎
  6. 1-9 ↩︎
  7. a-z ↩︎
  8. \01\02 ↩︎
  9. \t-\r ↩︎
  10. () ↩︎
  11. !-~ ↩︎
  12. \01\02 ↩︎
bump
was on 4.17, ive just upgraded to the latest version of ROS 5.
Ok i think i understand the symptom a little better.
whatever i set the max limit to on the main_out queue (parent=global out), it applies that limit to both main-in and main-out.
when i fire up a speedtest and watch the queue, I can see both main-in(global-in) and main-out(global-out) registering the same traffic at the same time.
So, im thinking it probably isn’t the mangle rules that are farged… its the Queue tree.
So the real question is why both queues are activated when one has a perent of global-in and the other has a parent of global-out?
Because global-out fires when the packets leave the router (after all, global-out sees all egress packets by design), and global-in fires when the packets come into the router (after all, global-in sees all ingress packets by design).
Use interface HTBs instead and assign interfaces as queue tree parents at the root. Interface HTBs only see egress packets leaving through that specific interface.
Thank you for the response.
I tried assigning the bridge, without any success, it just did not throttle at all. according to the queue trere it was like the traffic wasnt even there. when i tried setting both parent queues to ether 1, the download was not throttled, but the upload was.
Ok now we are getting somewhere, I thought about what you said and looked at the testing done so far and decided to put the download main queue with a parent of global_in and the upload queue of Ether 1. And i am now seeing proper speed throttleing of both download AND upload. BUT,
during download download queue registers 6meg. during upload test i see 2meg in the download queue AND the upload queue. and all traffic is being classified as “other” now.
My mangle rules are using the bridge as the in/out interface.
suggestions?
I removed
action=mark-packet chain=prerouting comment=“Everything else that remains” in-interface=bridge1 new-packet-mark=remaining_in passthrough=no
and
action=mark-packet chain=postrouting new-packet-mark=remaining_out out-interface=bridge1 passthrough=no
and the traffic is being classified as http again like its supposed to… I guess the “mark traffic as other” mangle rule is broken.
Still seeing download in the download queue and upload in both tho.
bump, any yall got a suggestion that can help clear this last hurdle?
bump
bump! Is this even really a problem? so long as my uploads are less than my downloads it should trottle speeds proper… im concearned about cpu usage being doubled if its in both queues tho. Is this something i should be concearned about?
bump
Ok so the trick here is that since I am transparently bridged, my mangle rules cannot use the bridge interface ethernet interfaces. I have to use src and dst IP addresses.
For example:
36 ;;; www HyperText Transfer Protocol
chain=prerouting action=mark-packet new-packet-mark=http_in
passthrough=yes dst-address=10.0.0.0/22 layer7-protocol=http
37 chain=postrouting action=mark-packet new-packet-mark=http_out
passthrough=yes src-address=10.0.0.0/22 layer7-protocol=http
Seems like a dumb mistake after i looked at the routeros diagram. Oh well, thanks to mikrotik support for getting me sorted!
any ideas why it would work with
but not address lists?
30 ;;; www HyperText Transfer Protocol
passthrough=yes dst-address-list=10.0.0.0/22, 192.168.0.0/22
Because that’s not how address lists work.
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Address_list
Make a named address list and put the subnets on it, then refer to the address list by name.
oh yeah! forgot how that works… I think ive used it only once before. thx.
I am ready to deploy this sucker into our second phase of testing on a small leg of our network, but something simple has me stumped.
This thing is totally transparent, so how do I assign an administrative IP that would be accessable on the same network?
I just added an IP to the bridge interface and It remained unreachable.
I shouldnt need to add a default route since It is not acting as a gateway right?
help a dummy out guys, Im sure this is something dumb that would be obvious to everyone else. Ive never tried to add an ip address to a fully transparent device before tho.
