Transparent mirroring of two ports with hAP-lite (like man-in-the-middle) ?
I recently bought an hAP-Lite (routerOS v6.25), I’m trying to use it for network testing.
What I’d like to configure is to have ports Ether3 and Ether3 somehow transparently mirrored - where anything received on Ether3 will be transmitted on Ether4 and vice-versa. Preferably, without changing even the Mac address of each frame.
(But I’d like to keep Ether1/Ether3/Wifi with the standard configuration of WAN/LAN/AP).
Is there a way to configure such a setup ?
Thanks,
  • J
check switch chip on menu “switch”
http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features
if supports mirroring you can do it
