hi all,
I'm using a routerboard and its parent proxy feature to forward requests to an external squid box.
Standard setup, I've got it running in other locations just fine.
Basically:
all clients are located on ether2 214.168.47.0/25
chain=dstnat src-address=!214.168.47.250 dst-address=!214.168.47.0/25
protocol=tcp dst-port=80 action=redirect to-ports=8000
ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8000
hostname: "proxy"
transparent-proxy: yes
parent-proxy: 214.168.47.250:3128
cache-administrator: "webmaster"
max-object-size: 10000KiB
cache-drive: system
max-cache-size: none
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 0KiB
reserved-for-ram-cache: 2048KiB
The issue is, the external squid box is returning an error to all the clients HTTP requests.
Read Error
(104) Connection reset
The only difference between this MT and other MT's in that are working is that this one has 2.9.13, while the others are still running 2.9.10
Have I missed something or is this a bug ?
Thanks ![]()
