I try with two methods,
- Method one.
[admin@MikroTik] ip firewall> /ip web-proxy print
enabled: yes
src-address: 0.0.0.0
port: 3128
hostname: “proxy”
transparent-proxy: yes
parent-proxy: 172.16.0.3:3128
cache-administrator: “lpdnadmin”
max-object-size: 4096KiB
cache-drive: secondary-master
max-cache-size: none
max-ram-cache-size: none
status: running
reserved-for-cache: 0KiB
reserved-for-ram-cache: 0KiB
chain=dstnat in-interface=bridge1 protocol=tcp dst-port=80 action=redirect to-ports=3128
But doing this all clients get this Miktrotik WEB-PROXY ( Squid inside mikrotik )
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://www.google.com.ar/
The following error was encountered:
- Access Denied.
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Your cache administrator is lpdnadmin.
Generated Fri, 22 Jun 2007 09:01:19 GMT by proxy (squid/2.5.STABLE11)
2. Method two.
chain=dstnat in-interface=bridge1 protocol=tcp dst-port=80 action=dst-nat to-addresses=172.16.0.3 to-ports=3128
But this causes error in my external Squid-box, the clients get this page error
While trying to retrieve the URL: /
- Invalid URL
Some aspect of the requested URL is incorrect. Possible problems:
- Missing or incorrect access protocol (should be `http://‘’ or similar)
- Missing hostname
- Illegal double-escape in the URL-Path
- Illegal character in hostname; underscores are not allowed
Your cache administrator is webmaster.
Generated Fri, 22 Jun 2007 08:50:51 GMT by digitalnet.local (squid/2.5.STABLE1)
SO where is there throuble.
