(I am a newbie!)
I have a scenario where I want to use RouterOS to sit inline on an Internet conenction and transparently pass all HTTP traffic to an external proxy server (as in a proxy server at another site). The original client address should be maintained for the packets sent to the proxy server.
Using a RB450 running 3.10 and have set up bridged ports for Eth1 and Eth5 so that it passes traffic. I have tested this and it is fine.
I have enabled proxy access using a parent-proxy and used IP Proxy Direct to make sure that all traffic is sent to the parent-proxy.
[admin@MikroTik] /ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 194.116.198.40
parent-proxy-port: 3128
cache-drive: system
cache-administrator: "webmaster"
max-cache-size: none
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
and IP PROXY DIRECT PRINT shows
DST-PORT DST-HOST PATH METHOD ACTION HITS
0 ... deny 0
So I think the proxy side is set up correctly.
To get traffic to be redirected I have told IP FIREWALL NAT to redirect packets:
[admin@MikroTik] /ip firewall nat> print
0 chain=dstnat action=redirect to-ports=8080 in-interface=ether5 dst-port=80
protocol=tcp
However nothing seems to be sent to the parent proxy, and I don't understand what I have missed?
Can anyone help?
