Transparent proxy
Can i make the transparent proxy work when mikrotik configured as a bridge?
Yes, refer to http://www.mikrotik.com/docs/ros/2.8/ip/firewall.content#6.35.2 foor more information.
Thanks,
Anyway, that seems to complicated to me, and it is done when using router.
I have my mikrotik configured as a bridge, not doing any routing or firewalling, i just shape traffic on this machine. I just wanted to activate web proxy, and its working OK, but i have to put ssetings on every users browses to use mikrotik IP adress and port 8080 as proxy server. I have somewhere read that it can not work as transparent proxy when configured in bridge mode, or it was only in 2.7 version?
Where can i find more specific info what firewall rules should i set to make it work transparent, and should i set it in interfaces/bridge/firewall
or on IP/firewall.
http://www.mikrotik.com/docs/ros/2.8/ip/webproxy.content#7.53.8.3
Edgars
try this:
/ip firewall dst-nat add dst-port=80 protocol=tcp action=redirect to-dst-port=8080 to-dst-address=ip.of.your.proxy
proxys work on layer 3 (IP, to be strictly: on layer 5) and bridges on layer 2, therefore no device is talking ip the bridge by default.
afaik transparent proxy working needs the router to be the default gateway.
regards.
matthias
