Transparent traffic shaping firewall mangle rules
Hey all,
I am wanting to do a transparent traffic shaper before my router that is doing PCC load balancing.
The problem I am having is that nothing is being marked on the firewall. I have a bridge setup and ether 2 and ether 3 added to the bridge and the bridge has enabled “Use IP Firewall”. Any idea why the traffic isn’t being caught by the firewall rules?
 ;;; DNS Traffic
      chain=prerouting action=mark-connection new-connection-mark=dns_conn
      passthrough=yes protocol=udp dst-port=53 log=no log-prefix=""
      passthrough=yes protocol=tcp dst-port=53 log=no log-prefix=""
 chain=prerouting action=mark-packet new-packet-mark=dns passthrough=no
      connection-mark=dns_conn log=no log-prefix=""
 ;;; HTTP Traffic
      chain=prerouting action=mark-connection new-connection-mark=http_conn
      passthrough=yes protocol=tcp dst-port=80,443 log=no log-prefix=""
chain=prerouting action=mark-packet new-packet-mark=http passthrough=no
      connection-mark=http_conn log=no log-prefix=""
;;; ICMP Traffic
      chain=prerouting action=mark-connection new-connection-mark=icmp_conn
      passthrough=yes protocol=icmp log=no log-prefix=""
chain=prerouting action=mark-packet new-packet-mark=icmp passthrough=no
      connection-mark=icmp_conn log=no log-prefix=""
;;; P2P Traffic
      chain=prerouting action=mark-connection new-connection-mark=p2p_conn
      passthrough=yes layer7-protocol=torrent-wwws log=no log-prefix=""
chain=prerouting action=mark-packet new-packet-mark=p2p passthrough=no
      connection-mark=p2p_conn log=no log-prefix=""
;;; Everything else
      chain=prerouting action=mark-connection new-connection-mark=other_conn
      passthrough=yes log=no log-prefix=""
chain=prerouting action=mark-packet new-packet-mark=other passthrough=no
      connection-mark=other_conn log=no log-prefix=""
bumping, wondering if I did something wrong, I followed the instructions via the Wiki, I tested it on my office connection and it worked, but not in quite the same setup as the production network I tried applying it to.
Thanks all!
Are the firewall enabled on bridges? You can do that under birdges and settings.
Your rules seem ok. Besides the ‘use ip firewall’ in bridge which has to be enabled and you did that, also ‘connection tracking’ has to be enabled in firewall.
I do have the use firewall in the bridge settings checked, I also tried disabling it and then enabling it again to see if there was something going on there. I had connection tracking set to auto, I changed it to yes and it still is not catching anything. I have also tried another RouterBoard (750G instead of a 450G) as well as an x86 box. same issue.
still a no-go, not sure why this is not working, has anyone else had this working on v6 of routerOS?
