Hello guys, ill go straight to the point.
I have a mikrotik router and a DSL. Behind mikrotik router is my whole LAN.
Mikrotik has 2 LAN cards (its a PC with 8GB flash card)
dsl modem : 192.168.1.1/24
ether1-dsl : 192.168.1.2/24
ether2-lan : 192.168.2.1/24
dhcp server on ether2 192.168.2.10-192.168.2.250
Now i set a web proxy up with transparency. I did that because i want my devices to access the internet faster with cached hosts and consume less bandwidth.
So when i finished with the masquarade in firewall for my NAT, i went to IP->web proxy
i clicked enabled, port 8989
max cache size 4gb
max clients 3000
max server connections 3000
TOS 10
max fresh time 190d
Then to firewall nat, i set a dstnat the whole 2.0/24 redirection to port 8989, the destination ports 80,3128 (protocol tcp)
After these settings i see in cache contents that mikrotik caches all traffic to these ports. However i want to exclude some certain IPs from the cache. Can you describe me a way to do it?
Thanks in advance guys!!!
