transparent web proxy not working
Can someone help me out, here is my config please spot my errors
interface enable ether1,ether2
ip dhcp-client set enabled=yes interface=ether1
ip address add address=10.20.0.1/24 interface=ether2
(by the way /24 what does that mean)
ip dns set allow-remote-request=yes
ip firewall src-nat add out-interface=ether1 action=masquerade
ip firewall rule input add /
connection-state=invalid action=drop
connection-state=established
connection-state=related
protocol=udp
protocol=icmp
src-address=10.20.0.0/24
action=drop log=yes
ip pool add name=private ranges=10.20.0.2-10.20.0.254
ip dhcp-server network add gateway=10.20.0.1 address=10.20.0.0/24 dns-server=10.20.0.1
ip dhcp-server add name=home interface=ether2 lease-time=3h address-pool=private
ip dhcp-server enable home
ip web-proxy set enable=yes port=8080 max-cache-size=unlimited
ip web proxy set transparent-proxy=yes
ip firewall dst-nat add in-interface=ether1 protocal=tcp dst:!:80 action=redirect to-dst-port=8080
please help me out, everything on the monitor area still ZERO
added
ip webproxy access
add src-address=10.20.0.0/24 action=allow disable=no
add action=deny disable=no
but still not work :cry: can anyone PLEASE HELP
regards
Robot
i have reformat the whole thing and follow exactly on the documents
/interface enable ether1,ether2
/ip dhcp-client set enabled=yes interface=ether1
/ip address add address=192.168.0.1/24 interface=ether2
/ip firewall rule input add connection-state=invalid action=drop
/ip firewall rule input add connection-state=established
/ip firewall rule input add connection-state=related
/ip firewall rule input add protocol=udp
/ip firewall rule input add protocol=icmp
/ip firewall rule input add src-address=192.168.0.0/24
/ip firewall rule input add action=drop log=yes
/ip pool add name=private ranges=192.168.0.2-192.168.0.254
/ip dhcp-server network add gateway=192.168.0.1 address=192.168.0.0/24 dns-server=192.168.0.1
/ip dhcp-server add name=home interface=ether2 lease-time=3h address-pool=private
/ip dhcp-server enable home
/ip web-proxy set enable=yes port=8080 max-cache-size=unlimited
/ip web proxy set transparent-proxy=yes
/ip firewall dst-nat add in-interface=ether1 protocal=tcp dst-address:!:80 action=redirect to-dst-port=8080
ip firewall dst-nat add in-interface=ether1 protocal=tcp dst-address:!192.168.0.1/24:80 action=redirect to-dst-port=8080 (this gives me an error : destination error) why ? anyone please explain to me?
web-proxy works alright !! BUT not the transparent :cry: can anyone HELP me out here, pleaseeeeeeeeeeeeeeeeeeeeee !
regards
Robot :cry:
/ip firewall dst-nat add in-interface=ether1 change to ether2 protocal=tcp dst-address:!:80 action=redirect to-dst-port=8080
the same in : ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address:!192.168.0.1/24:80 action=redirect to-dst-port=8080
yancho,
i have re-format the os and follow the same sets of instruction with your suggestions, but now the client MUST set their proxy before they can connect to the web, it is getting worst, can you please point out my errors.
regards
/ip firewall src-nat add out-interface=ether1 action=masquerade
/ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address:!:80 action=redirect to-dst-port=8080
/ip dns set allow-remote-request=yes
ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address:!192.168.0.1/24:80 action=redirect to-dst-port=8080 (this still gives me an error : destination error) why ? anyone please explain to me?
ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address=!192.168.0.1/24:80 action=redirect to-dst-port=8080
Eugene,
ERROR: destination bad :cry:
regards
with
ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address=!:80 action=redirect to-dst-port=8080
the transparent web proxy still wont work
but with
ip firewall dst-nat add in-interface=ether2 protocal=tcp action=redirect to-dst-port=8080
it works.
but will i would like to work with the dst-address=!192.168.0.1/24:80
PLEASE HELP ME OUT :cry:
regards
Ups, obviously, the mask should be /32 for a single host:
ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address=!192.168.0.1/32:80 action=redirect to-dst-port=8080
Eugene,
i’m new so please let me know
/32 for single host, by that you mean, single server or single broadband line
/24 for multiple host, and is there anything other than /32 and /24
regards
Robot714
http://public.pacbell.net/dedicated/cidr.html
on dst-nat remove the ! and it will work !!!
Nope, it should be there to allow accessing the router via Winbox.
Eugene,
with the /24 change to /32 the command “ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address:192.168.0.1/32!:80 action=redirect to-dst-port=8080” enter without error, but the problem is, the client station are not getting any gateway and dns-server ip address, is there any solution for that :cry: PLEASE HELP
regards
/ip address add address=192.168.0.1/32 interface=ether2
/ip firewall rule input add src-address=192.168.0.0/32
/ip dhcp-server network add gateway=192.168.0.1 address=192.168.0.0/32 dns-server=192.168.0.1
/ip firewall dst-nat add in-interface=ether2 protocal=tcp dst-address=!192.168.0.1/32:80 action=redirect to-dst-port=8080
You should have changed the mask only in one place (firewall nat), the other two addresses should have /24 mask:
Eugene,
What about "/ip firewall rule input add src-address=192.168.0.0/32 "
Thanks & Regards
Also should be /24
:smiley:
Eugene,
Thanks for everything, it works great now. Can you please let me know if there is any documents i can find on mikrotik for more detail setup guide or training materials.
Regards :smiley:
http://www.mikrotik.com/docs/ros/2.9/
http://www.mikrotik.com/docs/ros/2.8/
