Transparent WiFi AP
Hello.
I am trying to configure Mikrotik Groove 52HPn as an access point for a UDP camera stream (3 cameras to be exact). Cameras are connected by ethernet cable to Cloud Router Switch CR112-8G-45-IN. Groove is also connected with ethernet cable to that switch. Switch is unconfigured and is working as needed. PC1 is receaving stream from cameras without any problem. Cameras are broadcasting UDP RTP stream.
Groove is configured as ap-bridge, with a bridge configured on both ethernet and wlan interfaces.
However, the streams are not showing on PC2. What am I doing wrong with this configuration?
Try this:
  • Go to Wireless, open wlan1-gateway, click on [Advanced Mode] button, and set Multicast Helper to full.
You might also wish to set the Wireless Protocol to 802.11 instead of “any” :slight_smile:
