Transperant Proxy in a remote machine
Dear All,
I want to redirect all http traffic (IP network 10.0.0.0/24) from mikrotik box to a remote proxy server (203.112.204.241 and port 3128) running in linux/freebsd box.
How can Can I do it without using MT Web-Proxy ??
Please suggest.
regards,
Litu
DST NAT rule! :slight_smile: Or perferred, a web proxy with parent.
try to make a vpn between two sites that allows to see both ends and now in the mikrotik you can redirect the traffic to linux proxy
This is the config in MT (v3.28):
chain=dstnat action=dst-nat to-addresses=203.112.204.241 to-ports=3128 protocol=tcp src-address=10.0.0.0/24 dst-address=0.0.0.0/0 dst-port=80
My MT wan port IP is: 203.112.204.229
I got the following error in browser if i try to browse www.yahoo.com or anything :
ERROR
The Requested URL could not be retrieved
While trying to retrieve the URL: /
And in Squid log:
1256689646.668 1 203.112.204.229 TCP_DENIED/400 1437 GET / - NONE/- text/html
1256692810.831 1 203.112.204.229 TCP_DENIED/400 1437 GET / - NONE/- text/html
1256692812.014 1 203.112.204.229 TCP_DENIED/400 1437 GET / - NONE/- text/html
Any suggestion ??
Litu
Rather than redirect directly, it’s better to use the built in proxy with a parent proxy (your Squid box).
First enable the web proxy, and set up the parent:
/ip proxy set enabled=yes port=8000 parent-proxy=203.112.204.241
And then set up the transparent redirect:
/ip firewall nat add chain=dstnat action=redirect protocol=tcp dst-port=80 to-ports=8000 src-address=10.0.0.0/24
Then make sure that Squid is set up to answer those requests.
