I work for a WISP, and we currently have 2.4ghz network, a 700mhz network, and we use some 900mhz. The problems we are having is with our 2.4ghz network and the tranzeos. The tranzeos work, but the problem we are seeing is with all the CPQ’s (15,19,N). The towers we have are bridged from one another with point to points (usually cisco gear). The problem is customers will connect to a tower fine, but later on the SSID and customer name will change in the tranzeo!!!.. We have seen it from new firmware and old. Tranzeo tech support said they can’t do it, someone else is doing it…I doubt it… We have the passwords changed on the recovery and the write access…Any ideas???Please help because we spend a lot of money to do a truck roll and just do a few clicks boom boom and its fixed for now…
And another thing…we do dhcp and the tranzeo will go back to a static address…the default of 192.168.1.100…
