Is it supported?
http://www.mapleleaf-technologies.com/webstore/proddetail.php?prod=VikingADSL2
The Viking uses a Realtek 8139C+ chipset.
If the driver supports that chipset the card will work fine.
RouterOS doesn’t support any ADSL modems
Grrrr. This is very good card. I tried it at one seminar. We have lots of problems with classic ethernet adsl routers. I tried lot of them but all of them have some problems.
Can anyone then recommend me good adsl router?
The OS doesn’t see the ADSL side of it. The Viking looks and behaves like an ethernet card as far as the OS is concerned.
but I still guess you need drivers for the “ethernet side of it”, which RouterOS doesn’t have
I managed to get a Viking up and running on RouterOS 3.14.
It was detected as Realtek 8139, so it is supported by the driver.
ok interesting, and you managed to get connectivity to ADSL?
The Traverse ADSL2+ Card is a RTL8139 Nic and
a Conexant based ADSL2+ Modem/Router on a PCI card.
The config of the Modem/Router Part done via CLI / Telnet..
nice space saver
Does it working good and stable? Do You have any problems with it?
Yes, I got connectivity to ADSL. I used the PPPoE client and set the Viking up in bridge mode.
Yes it works fine. No problems.
This card is also available in the UK from http://www.oem-router-solutions.co.uk ![]()
https://www.oem-router-solutions.co.uk/oem-routers/56-solos-adsl2-pci-multiport-modem-card.html
Did anyone tried this card on MT?
The Solos multi-port card requires its own Linux driver, which isn’t included in MT yet.
I hope that MT will consider implementig support for this card. I have 14 ADLS lines. It would save me space, expenses, configuration…
MikroTik doesn’t plan to support any ADSL modems. Try using the mentioned VIKING card, which is supposed to be working
Fine !!!
AFTER I dump my ADSL for cable… !!!
I will have to dig one up to test…
Any news on the adsl2+ (annex-m maybe)?
The links don’t work and I would like to test the viking or any other card if they still exist.
The Viking and Solos cards still exist. Currently there are two distributors:
http://www.yawarra.com.au
http://traverse.kd85.com
http://www.traverse.com.au/distributors.php
Annex-M is technically possible on a Viking, but boards from the factory don’t have the extra components loaded.
Solos cards come with both Annex-A and Annex-M components loaded.
