Say address provided by my ISP is 1.2.3.4, my router is 192.168.1.1. My outside address is dynamic so I would like avoid hardcoding it into firewall rules.
I would like to set up routing in a way so if I connect to 1.2.3.4 from inside the network, traffic would behave as outside traffic and would go through normal NAT, filtering, etc. My previous routers done it that way be default.
Reson for this is testing, mainly. I would like to run nmap to see how my network looks from outside, test port forwards without using my cell phone, etc…
Browsing to 1.2.3.4:80 seems to work properly now.
However, I dislike following things:
it’s hacky as hell. I had to write a script (because NAT rules without my external IP went crazy).
when I run nmap 1.2.3.4 from inside of network, I would like to see same output as from outside. Currently it’s not the case. For example, I can see admin interface running at port 2222 and ssh 1.2.3.4 -p 2222 works.
Any thoughts?
Description of my current config follows.
I’m using following scheduled script to create address list with my outside address (patched together from various online sources):
