I have problem with triple dynamic load balancing on my NAT machine. Actually, there is no problem with load balancing but with WAN addresses which are in the same subnet, for example:
WAN-1= 188.2…/22
WAN-2= 188.2…/22
WAN-3= 188.2…/22
Those addresses have the same gateway which get from provider automatically via dhcp-client ether interfaces. By today, I had two WANs with same gateway and that has been working perfectly until I’ve put third WAN interface and get IP automatically. In that moment, all internet traffic on the network went down totally.
I forgot to mention that WAN-3 interface represents EoIP tunnel to the location where is located one x86 based MikroTik router with ethernet card directly connected to provider’s cable modem. On this router, there is one ether card, EoIP tunnel to NAT machine, bridged interfaces and this works extremly reliable.
So, my question is: How to prevent internet traffic goes down on NAT machine when third interface gets IP address from the same subnet and gets same gateway as WAN-1 and WAN-2.
No, EoIP was made directly to the second destination in local network. Entire network is routed with OSPF routing protocol. First two WANs are working independently. Third WAN is EoIP.
Two IP addresses from the same network assigned to routers different interfaces are not valid unless VRF is used. For example, the combination of IP address 10.0.0.1/24 on the ether1 interface and IP address 10.0.0.132/24 on the ether2 interface is invalid, because both addresses belong to the same network 10.0.0.0/24. Use addresses from different networks on different interfaces, or enable proxy-arp on ether1 or ether2.
First thing: This solution is not what I am using now and what i want on the network because I won’t use static load balancing by marking some packages but dynamic. I solved problem by including three RB750Gs on every WAN and everything works just perfectly.
Secong thing: I tried to solve problem on this way and all I want to say is that this is working with two WAN interfaces. In the moment I switch and apply those settings on thirs interface, all traffic on the network goes down, totally.
