i can`t enter on my router when i try to login when i use IP ADDRESS configured on a VLAN
Example:
Vlan 101
ip address: 172.18.0.1
try to connect to 172.18.0.1 via Winbox and the cannection not work, but with the MAC address i can,
can you help me?
Did you specify a subnet mask?
If not, the address is a /32 and can’t communicate anywhere.
So it should look like
/ip address add address=172.18.0.1/24 interface=vlan101
I guess your config looks like
/ip address add address=172.18.0.1 interface=vlan101
and won’t work.
-Chris
