I set up a DMZ on a Hex S to allow tinkering on a RB5009 without affecting the entire network. I created a dedicated bridge for the DMZ with a separate subnet and assigned eth3 (going to the RB5009) to it. I used dst-nat to forward all traffic to the RB5009 and set up some rules to drop traffic between the DMZ bridge and the existing ones. Isolated and independent configuration is working properly. However, I’d like to be able to configure the Hex S from behind the RB5009 occasionally. I forget everything I’ve tried and the RB5009 seems to have configured all the necessary routes, but no amount of changes I’ve made allow the connection through, though I can ping the Hex S all day. What am I missing? And is this DMZ set up correctly in the first place? Thank you for your help!
Filter and NAT rules on the Hex S. (The RB5009 has the default config)
/ip firewall nat print
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN
ipsec-policy=out,none
1 ;;; Rule to create 'DMZ' for Secondary Network
chain=dstnat action=dst-nat to-addresses=192.168.90.2
in-interface=ether1 log=no log-prefix=""
2 ;;; TCP: Deluge
chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=53400
protocol=tcp in-interface-list=WAN dst-port=53400 log=no log-prefix=""
3 X ;;; TCP: qBittorrent
chain=dstnat action=dst-nat to-addresses=192.168.88.9 to-ports=53398
protocol=tcp in-interface-list=WAN dst-port=53398 log=no log-prefix=""
4 X ;;; TCP: Transmission
chain=dstnat action=dst-nat to-addresses=192.168.88.10 to-ports=53399
protocol=tcp in-interface-list=WAN dst-port=53399 log=no log-prefix=""
5 ;;; UDP: Deluge
chain=dstnat action=dst-nat to-addresses=192.168.88.10 to-ports=53400
protocol=udp in-interface-list=WAN dst-port=53400 log=no log-prefix=""
6 X ;;; UDP: qBittorrent
protocol=udp in-interface-list=WAN dst-port=53398 log=no log-prefix=""
7 X ;;; UDP: Transmission
protocol=udp in-interface-list=WAN dst-port=53399 log=no log-prefix=""
8 X ;;; Allow return traffic for Management from Secondary Network
chain=srcnat action=accept src-address=192.168.90.0/24
dst-address=8.8.8.0/24 log=no log-prefix=""
9 X chain=srcnat action=accept protocol=tcp src-address=192.168.90.2
dst-address=192.168.90.1 out-interface=Secondary src-port=8728
dst-port=8728 log=no log-prefix=""
ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 X ;;; Allow management from Secondary Network
chain=input action=accept protocol=tcp src-address=8.8.8.0/24
dst-address=192.168.90.1 dst-port=8291 log=no log-prefix=""
2 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
3 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
4 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
5 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
6 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!BOTH log=no log-prefix=""
7 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
8 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
9 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection
10 ;;; defconf: accept established,related, untracked
11 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
12 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new
connection-nat-state=!dstnat in-interface-list=WAN log=no log-prefix=""
13 X chain=input action=accept connection-nat-state=dstnat protocol=tcp
14 ;;; Block wireless from accessing lan
chain=forward action=drop connection-state=new in-interface-list=WLAN
out-interface-list=LAN log=no log-prefix=""
15 ;;; Block LAN from accessing wireless
chain=forward action=drop connection-state=new in-interface-list=LAN
out-interface-list=WLAN log=no log-prefix=""
16 ;;; Block DMZ from accessing LAN and WLAN
chain=forward action=drop connection-state=new in-interface-list=DMZ
out-interface-list=BOTH log=no log-prefix=""
17 ;;; Block LAN and WLAN from accessing DMZ
chain=forward action=drop connection-state=new in-interface-list=BOTH
out-interface-list=DMZ log=no log-prefix=""
