Hoping someone can help me. I’m fairly new to using Mikrotik. I have a RB750GL at my home and I have another client of mine using a CRS109-8G-1S-2HnD-IN. I’m using this as a router on quick set as a “home AP”. I upgraded the software to 6.20 and checked the quick VPN option. All is good at this site. I am able to connect successfully connect to the site and login into the router to make changes.
To I set up another client of mine with the same router set up using quick set and as a “home AP”. I upgraded the software to 6.20 and set up the quick VPN. I am able to connect to the site successfully but I can not login into the router to do any changes to in. If I try the IP address of the router it never connects. I’ve tried to ping the router and it doesn’t work.
Is there something simple I’m missing or is there something I can try to fix this.
Thank you in advance for any info.
Sent from my iPhone using Tapatalk
