I am trying to create a vlan bridge with trunk ports on my CCR-1009 but it seems it is not working. I want to have Combo1 and ether2 as trunk ports on my CCR.
I have read a lot og posts and documentation but somehow something is not working - my laptops on the switch connected to the trunkports do not get an IP from the DHCP server.
Just to be sure I tested with another switch where I know the trunkport and VLAN 30 works and the same result, so right now I am ruling out the receiving end of the trunk, so the problem must be at the sending end.
When I torch the interface I can see VLAN tags of COMBO1 which is why I don’t understand why it is not working.
To start with I tested only with VLAN30 - when I get this working others will come.
My configuration is a per below - any hints ?
add frame-types=admit-only-vlan-tagged ingress-filtering=yes name=Trunk-bridge \
vlan-filtering=yes
add bridge=Trunk-bridge frame-types=admit-only-vlan-tagged ingress-filtering=\
yes interface=ether2
yes interface=combo1
/interface bridge vlan
add bridge=Trunk-bridge tagged=ether2,combo1 vlan-ids=30
/interface vlan
add interface=Trunk-bridge name=vlan30_trunk vlan-id=30
add address-pool=ipcam disabled=no interface=vlan30_trunk name=IPCAM
add address=10.30.30.0/24 comment=IPCAM dns-server=1.1.1.1 gateway=10.30.30.1
