I have a L009 running V7.12.1 that I configured DNAT rules to pass about ~20 different open ports to a server (on an internal 192.168.88.xx address). The L009 was WAN uplinked to a NID provided by my fiber ISP, which was initially set in it;s own dhcp routing mode. This configuration worked fine for about 6 months. I had an issue with my internet that was ultimately fixed by placing my NID into transparent bridging mode. on my L009, this changes how my eth1 detects internet, now it is not on the 192.168.0.1 network that the NID had, and is receiving (public IP) directly. Ports are no longer being forwarded to my server at 192.168.88.xx, and are instead only reaching my router. e.g. using my public IP in a web browser opens the router’s homepage instead of my web server, etc. I’ve tried a few different confiruation changes, as well as completely reset my router’s confiugraiton and did nothing but re-enable my DNAT rules as shown below.
Here’s some various printouts to show my current configuration:
/ip/firewall/nat print
Flags: X - disabled, I - invalid; D - dynamic
0 chain=srcnat action=masquerade out-interface-list=WAN
1 ;;; masq. vpn traffic
chain=srcnat action=masquerade src-address=192.168.89.0/24
2 ;;; http
chain=dstnat action=dst-nat to-addresses=192.168.88.52 to-ports=80 protocol=tcp in-interface-list=WAN dst-port=80
3 ;;; ssh
chain=dstnat action=dst-nat to-addresses=192.168.88.52 to-ports=22 protocol=tcp in-interface-list=WAN dst-port=22
4 ;;; Palworld UDP 8211
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=udp in-interface=ether1 dst-port=8211
5 ;;; Palworld TCP 8212
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=8212
6 ;;; Palworld TCP 25575
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=25575
7 ;;; Git TCP 3000
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=3000
8 ;;; DNS TCP 53
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=53
9 ;;; DNS UDP 53
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=udp in-interface=ether1 dst-port=53
10 ;;; DNS TCP 853
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=853
11 ;;; DNS UDP 853
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=udp in-interface=ether1 dst-port=853
12 ;;; SFTP TCP 222
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=222
13 ;;; SSH TCP 22
14 ;;; HTTP TCP 80
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=80
15 ;;; Alternative HTTP TCP 81
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=81
16 ;;; HTTPS TCP 443
chain=dstnat action=dst-nat to-addresses=192.168.88.52 protocol=tcp in-interface=ether1 dst-port=443
/ip/firewall/filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 chain=input action=accept protocol=icmp
2 chain=input action=accept connection-state=established
3 chain=input action=accept connection-state=related
4 ;;; allow l2tp
chain=input action=accept protocol=udp dst-port=1701
5 chain=input action=drop in-interface-list=!LAN
/ip/route print
/ip/route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, d - DHCP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 [PUBLIC IP] 1
DAc [PUBLIC IP]/19 ether1 0
DAc 192.168.88.0/24 bridge 0
/interface/list print
Flags: * - BUILTIN
Columns: NAME
# NAME
;;; contains all interfaces
0 * all
;;; contains no interfaces
1 * none
;;; contains dynamic interfaces
2 * dynamic
;;; contains static interfaces
3 * static
;;; defconf
4 WAN
;;; defconf
5 LAN
