Hi, I’m trying to establish a L2TP tunnel between two Mikrotik; this is client-side configuration:
/ interface l2tp-client
add name="hotspot-mng" max-mtu=1460 max-mru=1460 connect-to=111.22.33.44 \
user="login@realm" password="password" profile=hotspot-mng \
add-default-route=no allow=mschap2 disabled=no
/ ppp profile
add name="hotspot-mng" use-compression=default use-vj-compression=default \
use-encryption=default only-one=default change-tcp-mss=default comment=""
The error I got on server-side is:
l2tp info first L2TP UDP packet received from 88.99.xx.yy
On the same server I’ve several other L2TP tunnel (same configuration) that are working fine.
What can I check?
Thank you!
