Initially it seemed to boot fine (i.e. sound is heard, beep and then some fast beeps) but the board never showed up in winbox.
Then it just stopped. When I plug it in (both with power adapter 12v and a 24V gigabit PoE injector) 4 of 5 LEDS (left of the Ethernet ports) go on and remain on with no sound.
I tried shorting the kidney bean shaped contacts marked reset and powering it up, as well as the button between the serial port and eth1 with no luck.
I unfortunately do not have a null modem cable to check what is produced on the serial console.
Does anyone have any suggestions? Is this a known issue with new boards.
Tested at the distributor, and he could connect. Got home, no winbox, did a netinstall and it could see the board. Upgraded to 6.26, netinstall reported success after a reboot. Then on the next boot, nothing again. Same symptoms.
I tried attaching a serial cable, but I see nothing on the console and no, I have not added an SD card to it.
I swapped it out again, the distributor’s technical guys can’t seem to figure it out.
There are 5 LEDs next to the USB interface. After a successful boot these are all off. Currently I see 4 of them on (LD41 - LD44). Does anyone know what this means?
Reset’s do not work, nothing comes up. Please help
