Trouble with Port Forwarding rb951ui
I have a trouble setting port forwarding on MicroTIk rb951ui-2hnd firmware 6.36.3
I have Ethernet 1 set up as WAN port (10.x.x.x).
Via wifi i’ve connected PC with ftp service running (192.168.88.2). - IP address is statically asigned on pc. DHCP pool on mikrotik is 192.168.88.10-192.168.88.250
In Mikrotik web interface i’ve disabled in “IP” → “Services” ftp service. As i was getting into routers ftp.
After that i’ve set up Nat rules to forward port 21 to local pc.
Here;s my configuration
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.88.1/24    192.168.88.0    bridge
 1 D 10.x.x.x/24  10.x.x.0    ether1-wan
[admin@MikroTik] > /ip firewall nat print
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface=ether1-wan
 1    chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=21
      protocol=tcp dst-address=10.x.x.x in-interface=ether1-wan
      dst-port=21 log=no
 2    chain=srcnat action=src-nat to-addresses=10.x.x.x to-ports=21
      protocol=tcp src-address=192.168.88.2 src-port=21 log=no
 3  D ;;; upnp 192.168.88.2: Teredo
      chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=55088
      protocol=udp dst-address=10.x.x.x in-interface=ether1-wan
      dst-port=55088
 4  D ;;; upnp 192.168.88.2: Skype UDP at 192.168.88.2:41168 (3540)
      chain=dstnat action=dst-nat to-addresses=192.168.88.2 to-ports=41168
      dst-port=41168
 5  D ;;; upnp 192.168.88.2: Skype TCP at 192.168.88.2:41168 (3540)
[admin@MikroTik] > /ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward
 1    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
 2    ;;; defconf: accept established,related
      chain=input action=accept connection-state=established,related
 3    ;;; defconf: drop all from WAN
      chain=input action=drop in-interface=ether1-wan
 4    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection
 5    ;;; defconf: accept established,related
      chain=forward action=accept connection-state=established,related
 6    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
I’ve also tried disabling drop-filter rules, but i still can’t rich my local ftp. Any help will be greatly appreciated.
I also tried to create accept-filter rule for input chain with in. interface set as ethernet 1 and dst port as 21 and put it on top of the list. still no luck
You need an accept rule in the Forward chain. Input is for traffic going to the the router itself, forward is for traffic passing through it.
    add action=accept chain=forward comment="Accept DST-NATed to Clients" \
    connection-nat-state=dstnat in-interface=ether1-wan
This will accept any dst-nat rule you add instead of adding individual rules.
Also you do not need the src-nat you have from your ftp server as that is handled by you masquerade rule.
Thanks for the reply. I’ve just come across similar advice, but was recommended to choose !ether1-wan (not). Anyway, it doesn’t help. But if i set NOT ether1-wan the counter of packets on that rule runs.
The funny part is that UPnP rules are created, look identical to mine and work =/
Are you testing this from an external source? Or are you using another device in the same network just trying connect to the external IP? If you are trying the later you will also need a Hairpin NAT.
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=192.168.88.2 out-interface="bridge" src-address=192.168.88.0/24
Your tip + changing “In. Interface” to blank and setting “Dst. Address Type” to “local” helped to solve the iisue! Thanks A lot for fast response! Now i can go to sleep)))
But why could it not work when i set up in. interface as ether1-wan or dest ip as 10.x.x.x? =/
