Trouble with RB33+XR2+Sector 120º antenna
Hi all, I have a Pacific Wireless Sector Antenna 120º 16DBi, 2300-2700 ghz in a Cellulars tower. It’s serving 40 clients with a Linksys WRT54GL but they are too much for the Linksys, so I bought a RB333 with a Ubiquity XR2 card. The problem is that when I connected the RB333, all clients reported very high Signal Strenght with huge number of errors (CCQ 5%), and a lot of “Disconnected, Extensive Data Loss”. Finally every 2-3 minuts, everybody is disconnected.
Any suggestion how to resolve this issue?
Thank you and best regards
Try turning down the power on the AP. You went from a 75 mw radio to a 600mw radio. It is blasting the clients and it also has superior sensitivity so it can hear a lot more including both clients and noise.
You might also try some different frequency settings.
It sounds like there is too much noise (low CCQ). The loudest radio is not always the best.
Good luck,
Tom
Thanks Tom for your help. I will try but I’m pretty sure that I have a lot of interference (there are 2 GSM and TDMA cellular companies, an analog TV repeater, and some FM radios together in the same tower) What do you think about a passband filter?
Best regards
Start by posting your configuration so we can see if there is anything obviously wrong.
Hi: in wlan1 I have a 14dbi Pacific Wireless Backfire antenna, with 50 clientes. In wlan2 I have a 16 dbi 120º Sectorial Pacific Wireless. Both interfaces are Ubiquity XR2. I can’t transfer clients to wlan2 because I got too much errors in the client side (MT report 92% CCQ for example, but the CPE report 238:1 errors
CLIENT SIDE:
eth1 Link encap:Ethernet HWaddr 00:1C:10:D1:CF:67
inet addr:192.168.111.154 Bcast:192.168.111.255 Mask:255.255.255.128
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:430 errors:0 dropped:0 overruns:0 frame:102504
TX packets:215 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:32111 (31.3 KiB) TX bytes:21946 (21.4 KiB)
MT SIDE:
interface=wlan2 mac-address=00:1C:10:D1:CF:67 ap=no wds=no rx-rate=“5.5Mbps” tx-rate=“11Mbps” packets=176,168
bytes=16548,15844 frames=176,168 frame-bytes=15540,14836 hw-frames=202,168 hw-frame-bytes=22780,18868
tx-frames-timed-out=0 uptime=2m54s last-activity=650ms signal-strength=-75dBm@5.5Mbps signal-to-noise=20dB
strength-at-rates=-75dBm@1Mbps 7s650ms,-75dBm@2Mbps 17s650ms,-75dBm@5.5Mbps 650ms,-75dBm@11Mbps 18s660ms tx-ccq=92%
p-throughput=5558 ack-timeout=56 last-ip=192.168.111.154 802.1x-port-enabled=yes wmm-enabled=no
[root@CIDIS-ANTEZANA] /interface wireless> print advanced
0 R name=“wlan1” mtu=1500 mac-address=00:15:6D:63:D2:5F arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“00156D63D25F” mode=ap-bridge ssid=“CIDIS-REP1” area=“”
frequency-mode=manual-txpower country=bolvia antenna-gain=0
frequency=2447 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=21 tx-power-mode=all-rates-fixed
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=10s default-authentication=no
default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=4
frame-lifetime=0 adaptive-noise-immunity=yes
1 R name=“wlan2” mtu=1500 mac-address=00:15:6D:63:82:0A arp=enabled
radio-name=“00156D63820A” mode=ap-bridge ssid=“CIDIS-REP5” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=16
frequency=2427 band=2.4ghz-b/g scan-list=default rate-set=default
54Mbps
dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
