Hello. I have router hap ac^2, version RouterOS - 6.43.11. I want use SMB with external USB-HDD. My config on router:
/ip smb> print
enabled: yes
domain: WORKGROUP
comment: MikrotikSMB
allow-guests: yes
interfaces: all
/ip smb> shares print
Flags: X - disabled, I - inactive, * - default
NAME DIRECTORY MAX-SESSIONS
0 * ;;; default share
pub /flash/pub 10
1 Docs /disk1/Docs 15
/ip smb> users print
Flags: * - default, X - disabled
NAME PASSWORD READ-ONLY
0 * guest yes
1 gravis gravis no
I check this with "net use" on workstation with Win10 x64. "Net use" say me "Connect OK", but i can't open my folder. On screen i check folder "Docs" on HDD, but if i check folder Pub on router - i'm getting the same. In logs on router all fine, screen attached too.
What could be the problem? Thx.
P.S. Sorry for my bad English, i'm from Russia and my bear knows English badly ![]()
