I have a newly purchased RB750GL:
[admin@mikrotik2] /system license> /system routerboard print
routerboard: yes
model: "750GL"
serial-number: "2CFA0119D664"
current-firmware: "2.35"
upgrade-firmware: "2.34"
[admin@mikrotik2] /system license> /system license print
software-id: "****-****"
upgradable-to: v7.x
nlevel: 4
features:
I’m migrating my firewall config from a dedicated linux machine to the RB750GL, and am having some issues with a bit of code that dynamically adds an entry to the beginning of the nat chain. The extra nat entry is added through use of an ssh command from a linux host. I have traced the problem to be the place-before option (this appears as an option on the command line, but not documented in the wiki). Here’s what I’m doing:
Works:
[user1@admin1 bin]# ssh admin@mikrotik2 /ip firewall nat add chain=dstnat src-mac-address=18:20:32:EC:B9:59 in-interface=vlan60 action=accept comment=192.168.60.201
Fails:
[user1@admin1 bin]# ssh admin@mikrotik2 /ip firewall nat add chain=dstnat src-mac-address=18:20:32:EC:B9:59 in-interface=vlan60 action=accept place-before=0 comment=192.168.60.201
sequential access failure, item list changed (11)
When running the command from the RB750 itself, it works:
[admin@mikrotik2] /ip firewall nat> /ip firewall nat add chain=dstnat src-mac-address=18:20:32:EC:B9:59 in-interface=vlan60 action=accept place-before=0 comment=192.168.60.201
[admin@mikrotik2] /ip firewall nat> print chain=dstnat
0 ;;; 192.168.60.201
chain=dstnat action=accept in-interface=vlan60 src-mac-address=18:20:32:EC:B9:59
I have created a script file and running it directly from the console works (/import test.rsc), but running it non-interactively fails (ssh mikrotik /import test.rsc).
I’d love to hear any ideas on how to get this working - either using the place-before option, or some more ingenious (or possibly blindingly obvious) method.
Regards,
Steve
