I am having trouble with some configuration on the CRS kit. everything works great for a couple of hours and then I start to lose packets and my pppoe connections start to drop out
Restarting the kit seems to work for a while and then it all goes bad again
below is a config export, can anyone point me in the right direction?
[admin@Core-Sw1 External Cab] > export
oct/19/2016 23:00:09 by RouterOS 6.34.2
software id = 4T7E-FMX0
add name=bridgeTunk
add name=bridge_access_vlan10_mgt
add name=bridge_access_vlan20_PPPoE
add name=bridge_access_vlan90_TTB
set [ find default-name=ether1 ] advertise=10M-half,10M-full name=
"ether1-master PPPoE"
set [ find default-name=ether2 ] master-port="ether1-master PPPoE"
set [ find default-name=ether3 ] master-port="ether1-master PPPoE"
set [ find default-name=ether4 ] master-port="ether1-master PPPoE"
set [ find default-name=ether5 ] master-port="ether1-master PPPoE"
set [ find default-name=ether6 ] master-port="ether1-master PPPoE"
set [ find default-name=ether7 ] master-port="ether1-master PPPoE"
set [ find default-name=ether8 ] master-port="ether1-master PPPoE"
set [ find default-name=ether9 ] master-port="ether1-master PPPoE"
set [ find default-name=ether10 ] master-port="ether1-master PPPoE"
set [ find default-name=ether11 ] master-port="ether1-master PPPoE"
set [ find default-name=ether12 ] master-port="ether1-master PPPoE"
set [ find default-name=ether13 ] master-port="ether1-master PPPoE"
set [ find default-name=ether14 ] master-port="ether1-master PPPoE"
set [ find default-name=ether15 ] master-port="ether1-master PPPoE"
set [ find default-name=ether16 ] master-port="ether1-master PPPoE"
set [ find default-name=ether17 ] master-port="ether1-master PPPoE"
set [ find default-name=ether18 ] master-port="ether1-master PPPoE"
set [ find default-name=ether19 ] master-port="ether1-master PPPoE"
set [ find default-name=ether20 ] master-port="ether1-master PPPoE"
set [ find default-name=ether21 ] master-port="ether1-master PPPoE"
set [ find default-name=ether22 ] name="ether22 - VlanTrunk"
set [ find default-name=ether23 ] name="ether23 - TTB"
set [ find default-name=ether24 ] name="ether24 - MGT"
set [ find default-name=sfp-sfpplus1 ] master-port="ether1-master PPPoE"
set [ find default-name=sfpplus2 ] master-port="ether1-master PPPoE"
/interface vlan
add interface=bridgeTunk name=vlan10_mgt vlan-id=10
add interface=bridgeTunk name=vlan20_PPPoE vlan-id=20
add interface=bridgeTunk name=vlan90_TTB vlan-id=90
add bridge=bridgeTunk interface="ether22 - VlanTrunk"
add bridge=bridge_access_vlan10_mgt interface="ether24 - MGT"
add bridge=bridge_access_vlan10_mgt interface=vlan10_mgt
add bridge=bridge_access_vlan90_TTB interface="ether23 - TTB"
add bridge=bridge_access_vlan90_TTB interface=vlan90_TTB
add bridge=bridge_access_vlan20_PPPoE interface="ether1-master PPPoE"
add bridge=bridge_access_vlan20_PPPoE interface=vlan20_PPPoE
add address=192.168.100.248/24 comment=defconf interface="ether1-master PPPoE"
network=192.168.100.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=bridge_access_vlan10_mgt
add default-route-distance=0 dhcp-options=hostname,clientid interface=
vlan10_mgt
/lcd interface pages
set 1 interfaces=ether13
/system clock
set time-zone-name=Europe/London
/system identity
set name="Core-Sw1 External Cab"
/system scheduler
add interval=1d name=DailyReboot on-event="system reboot" policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=
mar/10/2016 start-time=03:00:00
/tool sniffer
set file-limit=70000KiB file-name=switch.pcap filter-interface=
"ether1-master PPPoE" memory-limit=10000KiB
