Troubles to connect via LAN to "the Dude"
Here I am:
Dude running onto a Suse server.
Every thing is okay : I can connect with a client CPU when I’m plugged directly to the switch right to the server.
So it means . Dude looks correctly intalled and I got no trouble / firewall 'settings.
But :
I’ve tried to establish a remote connection.
Same LAN , only one wireless point to point (max bandwidth = 6Mo/sec…) is separating me from the dude’s server:
C:\Users\UTILISATEUR>tracert 192.168.0.8
Détermination de l’itinéraire vers 192.168.0.8 << my dude’s server
avec un maximum de 30 sauts :
1 <1 ms <1 ms <1 ms http://www.mydudeserver.com [192.168.0.8]
tracert ok
So I “Wiresharked” my dude server to go forward to find the reason why:
I 've got some Checksum error, some bad tcp anaylis flags…
here is a copy of my problematic sniffed packet :
_TCP. src port 2210 , distant port 63835 …ack sequence n° …
Checksum : 0a472 [incorrect, should be 0993a (maybe caused by checksum offloadind?)]_
Now I need some help :/, coz I really need some remote access.
I m already using many mikrotic’s routers…got lot of devices to secure and to manage…
Thx alot for some help :slight_smile:
I could give you my skype Id …
-Nicolas-
Do I need to add some infos ?
Plz tell me I will answer coz I really need some help :confused:
Hi … It 's me … Again ^_^.
I think I have a part of the clue. But need ur help:
When The link is starting betwen my CPU & dude’s server, the connection is starting onto :2210.
primary connections are established. I can see some UL and DL onto my remote client… but the it stop.
Because I noticed this with wireshark:
Then The dude 's server is answering to my CPU:
BUT : The port it’s using to answer is never the same… 63606,60478..etc etc =)
So i suppose it got to be important to open a specific port onto my router between me and the dude server), to be able to let that answer pass throught it. ( settings on the router are the default ones.)
I had a look in settings, but I cant find a way to block that answer onto one specific port. e.g: 60470.
( I can precise I’m using the dude v2.0) on both CPU, because I had some troubles / with the other version… )
Thx for support.
Best regards.
