Troubles updating with the auto update tool
so a couple of days ago I bought RB951Ui-2HnD, today I decided to configure it and everything just worked without headaches. On the box there was a text saying to update the router version for better experience. First thing after configure was to try to update it, I decided to use the easiest way the auto update tool. I’ve logged into the router in the WEB GUI → Quick Set → Check For Updates and Error message appeared File not Found. I think I’m using version 6.0 r13 or something similar.
Any suggestions?
Regards
Hey, update manualy like this http://www.wirelessinfo.be/index.php/mikrotik/pages/upgrade
From then on will work the auto update tool
