Troubleshooting router spontaneous restart
Hi !
I have RB 2011 that have connection to internet provider via PPPoE.
From time to time (weekly or one per two days) I see that router restarts without any reasons. I can see in log only following message: system,error,critical - router was rebooted without proper shutdown. No any issues with CPU and memory load according to PRTG.
What can I activate in logs to have more details about this event ?
This is strange.
For getting more detailed (well, any hints in this case), you should log errors - and probably criticals as well - to disk.
So they will survive reboots and you can analyze them after the restart:
/system logging
set topics=error action=disk
set topics=critical action=disk
-Chris
Thank you Chris !
Yes, I save my logs on disk. I hope size of disk will be enough for that.
I set logging paremeters:
Flags: X - disabled, I - invalid, * - default
TOPICS ACTION PREFIX
0 * info disk
!dhcp
1 * error disk
2 * warning disk
3 * critical disk
[MikroTik] >
But don’t see any aditional messaged after restart.
The same story, only one message:
Any ideas ?
Hmmm… maybe just a faulty PSU or connector?
Short answer:
  1. Try another router
Long answer:
  1. Try another power supply
  2. Try another power outlet
  3. Put it on a UPS
If you suspect that your power fluctuates, a power conditioner couldn’t hurt. Some UPS devices do this. I had a MikroTik device behave strangely after a lightning strike. This just happens.
If you still have the problem with a new power supply and UPS, you just have a bad machine. Luckily they aren’t too expensive to replace.
Hi, thank you all for responses !
Mikrotik is connected to UPS. So, it seems there is no problem with power.
I found interesting regularity. Before reboot appears message from SNTP service:
example from log
sntp change time Aug/12/2017 01:36:23 => Aug/12/2017 05:11:38
Here is part of log for your review, just pay attention to timestamps and two messages:
system,info sntp change time …
system,error,critical router was rebooted without proper shutdown
aug/12 00:58:50 pppoe,ppp,info pppoe-out1: connecting…
aug/12 00:58:50 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 00:58:50 pppoe,ppp,info pppoe-out1: disconnected
aug/12 00:59:00 pppoe,ppp,info pppoe-out1: initializing…
aug/12 00:59:00 pppoe,ppp,info pppoe-out1: connecting…
aug/12 00:59:00 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 00:59:00 pppoe,ppp,info pppoe-out1: disconnected
aug/12 00:59:10 pppoe,ppp,info pppoe-out1: initializing…
aug/12 00:59:10 pppoe,ppp,info pppoe-out1: connecting…
aug/12 00:59:10 pppoe,ppp,info pppoe-out1: authenticated
aug/12 00:59:10 pppoe,ppp,info pppoe-out1: connected
aug/12 00:59:11 system,info item added
aug/12 01:30:48 system,info sntp change time Aug/12/2017 00:59:17 => Aug/12/2017 01:30:48
aug/12 01:30:53 system,error,critical router was rebooted without proper shutdown
aug/12 01:30:55 interface,info vlan_6 link up
aug/12 01:30:55 interface,info vlan_10 link up
aug/12 01:30:55 interface,info vlan_20 link up
aug/12 01:30:55 interface,info vlan_30 link up
aug/12 01:30:57 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:30:57 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:30:57 interface,info ether1-gateway link up (speed 100M, full duplex)
aug/12 01:30:58 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:30:58 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:30:58 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:30:58 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:30:58 interface,info ether2 link up (speed 1G, full duplex)
aug/12 01:30:59 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:30:59 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:30:59 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:30:59 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:01 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:01 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:01 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:01 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:04 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:04 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:04 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:04 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:11 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:11 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:11 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:11 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:21 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:21 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:21 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:21 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:31 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:31 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:31 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:31 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:41 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:41 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:41 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:41 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:31:51 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:31:51 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:31:51 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:31:51 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:01 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:01 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:02 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:02 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:12 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:12 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:12 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:12 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:22 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:22 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:22 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:22 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:32 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:32 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:32 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:32 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:42 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:42 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:42 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:42 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:32:52 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:32:52 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:32:52 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:32:52 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:02 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:02 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:02 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:02 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:12 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:12 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:12 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:12 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:22 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:22 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:22 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:22 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:32 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:32 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:33 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:33 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:43 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:43 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:43 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:43 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:33:53 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:33:53 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:33:53 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:33:53 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:03 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:03 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:03 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:03 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:13 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:13 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:13 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:13 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:23 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:23 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:23 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:23 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:33 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:33 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:33 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:33 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:43 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:43 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:43 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:43 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:34:53 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:34:53 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:34:54 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:34:54 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:04 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:04 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:04 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:04 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:14 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:14 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:14 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:14 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:24 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:24 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:24 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:24 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:34 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:34 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:34 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:34 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:44 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:44 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:44 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:44 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:35:54 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:35:54 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:35:54 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate ourselves to peer
aug/12 01:35:54 pppoe,ppp,info pppoe-out1: disconnected
aug/12 01:36:04 pppoe,ppp,info pppoe-out1: initializing…
aug/12 01:36:04 pppoe,ppp,info pppoe-out1: connecting…
aug/12 01:36:04 pppoe,ppp,info pppoe-out1: authenticated
aug/12 01:36:04 pppoe,ppp,info pppoe-out1: connected
aug/12 01:36:04 system,info item added
aug/12 05:11:38 system,info sntp change time Aug/12/2017 01:36:12 => Aug/12/2017 05:11:38
aug/12 08:01:18 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.62 for 3C:D0:F8:8C:6C:6A without success
aug/12 08:41:30 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.70 for 30:A8:DB:BA:8F:B6 without success
aug/12 11:21:05 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.70 for 30:A8:DB:BA:8F:B6 without success
aug/12 12:33:48 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.70 for 30:A8:DB:BA:8F:B6 without success
aug/12 14:26:14 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.70 for 30:A8:DB:BA:8F:B6 without success
aug/12 18:52:05 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.76 for 58:48:22:5D:4D:37 without success
aug/12 18:52:48 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.76 for 58:48:22:5D:4D:37 without success
aug/13 00:16:28 pptp,info TCP connection established from 192.168.1.116
aug/13 04:10:05 pptp,info TCP connection established from 139.162.102.46
aug/13 06:35:58 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.72 for AC:C1:EE:8C:66:B3 without success
aug/13 06:58:14 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.72 for AC:C1:EE:8C:66:B3 without success
aug/13 10:51:47 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 11:17:50 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 11:18:13 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 11:19:48 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 11:29:51 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.64 for 00:5A:26:45:24:C4 without success
aug/13 11:59:32 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:02:59 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:03:20 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:28:22 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:29:02 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:31:57 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:33:52 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 12:47:44 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.135 for A0:32:99:44:92:9C without success
aug/13 14:25:42 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:26:32 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:26:43 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.136 for 34:14:5F:97:FB:B9 without success
aug/13 14:27:17 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:27:57 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:28:56 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.136 for 34:14:5F:97:FB:B9 without success
aug/13 14:42:20 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:42:54 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:43:29 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 14:43:52 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/13 18:06:55 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.135 for A0:32:99:44:92:9C without success
aug/14 09:06:34 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.181 for 00:00:FA:61:24:FA without success
aug/14 09:37:15 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.103 for B4:8B:19:27:3C:B8 without success
aug/14 09:42:06 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/14 12:21:59 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.175 for C4:B3:01:C5:75:B5 without success
aug/14 12:39:00 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.128 for 30:A8:DB:BA:8F:B6 without success
aug/14 13:02:52 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.181 for 00:00:FA:61:24:FA without success
aug/14 13:27:23 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.64 for 00:5A:26:45:24:C4 without success
aug/14 13:28:06 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.64 for 00:5A:26:45:24:C4 without success
aug/14 20:32:57 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.162 for 70:0B:C0:7B:79:C5 without success
aug/14 05:11:42 system,error,critical router was rebooted without proper shutdown
aug/14 05:11:46 interface,info vlan_6 link up
aug/14 05:11:46 interface,info vlan_10 link up
aug/14 05:11:46 interface,info vlan_20 link up
aug/14 05:11:46 interface,info vlan_30 link up
aug/14 05:11:47 pppoe,ppp,info pppoe-out1: initializing…
aug/14 05:11:47 pppoe,ppp,info pppoe-out1: connecting…
aug/14 05:11:48 interface,info ether1-gateway link up (speed 100M, full duplex)
aug/14 05:11:49 pppoe,ppp,info pppoe-out1: authenticated
aug/14 05:11:49 pppoe,ppp,info pppoe-out1: connected
aug/14 05:11:50 system,info item added
aug/14 05:11:50 interface,info ether2 link up (speed 1G, full duplex)
aug/15 00:00:41 system,info sntp change time Aug/14/2017 05:12:14 => Aug/15/2017 00:00:41
aug/15 08:09:09 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/15 08:09:42 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/15 08:10:23 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/15 08:10:53 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/15 13:44:37 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.110 for 34:BE:00:52:D8:BE without success
aug/15 15:37:09 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/15 16:04:57 ssh,info auth timeout
aug/15 16:21:55 ssh,info auth timeout
aug/15 16:28:46 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.71 for 9C:5C:F9:52:A3:AF without success
aug/16 08:59:49 pptp,info TCP connection established from 164.52.7.134
aug/16 08:59:52 pptp,info TCP connection established from 164.52.7.134
aug/16 13:06:14 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/16 13:06:45 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/16 13:07:31 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.60 for DC:CE:BC:AB:6A:F1 without success
aug/16 13:25:10 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/16 13:31:46 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for 00:00:FA:61:24:FA without success
aug/16 00:00:45 system,error,critical router was rebooted without proper shutdown
aug/16 00:00:48 interface,info vlan_6 link up
aug/16 00:00:48 interface,info vlan_10 link up
aug/16 00:00:48 interface,info vlan_20 link up
aug/16 00:00:48 interface,info vlan_30 link up
aug/16 00:00:50 pppoe,ppp,info pppoe-out1: initializing…
aug/16 00:00:50 pppoe,ppp,info pppoe-out1: connecting…
aug/16 00:00:50 interface,info ether1-gateway link up (speed 100M, full duplex)
aug/16 00:00:52 pppoe,ppp,info pppoe-out1: authenticated
aug/16 00:00:52 pppoe,ppp,info pppoe-out1: connected
aug/16 00:00:52 system,info item added
aug/16 00:00:52 interface,info ether2 link up (speed 1G, full duplex)
aug/16 15:11:08 system,info sntp change time Aug/16/2017 00:01:17 => Aug/16/2017 15:11:08
aug/16 18:42:57 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.64 for BC:E5:9F:3E:F3:0E without success
aug/17 06:07:26 system,info,account user strelok logged in from 77.37.236.215 via winbox
aug/17 06:11:58 system,info,account user strelok logged out from 77.37.236.215 via winbox
aug/17 06:12:25 pptp,info TCP connection established from 139.162.102.46
aug/17 07:43:44 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for A0:32:99:44:92:9C without success
aug/17 07:44:45 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.63 for A0:32:99:44:92:9C without success
aug/17 08:52:00 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 10:42:30 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 10:45:06 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 10:48:05 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 12:40:11 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.110 for 34:BE:00:52:D8:BE without success
aug/17 13:17:51 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 13:23:47 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/17 14:11:45 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/17 22:44:15 pptp,info TCP connection established from 94.102.49.193
aug/18 01:42:53 pptp,info TCP connection established from 139.162.102.46
aug/18 08:38:41 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/18 10:45:02 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.60 for DC:CE:BC:AB:6A:F1 without success
aug/18 11:19:11 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/18 11:52:58 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.58 for 4C:66:41:7F:56:38 without success
aug/18 12:10:44 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.200 for D8:BB:2C:A1:AB:C7 without success
aug/18 13:06:00 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:06:31 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:07:12 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:07:54 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:09:12 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:09:53 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:10:47 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:13:16 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/18 13:14:51 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:17:43 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:19:08 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:20:42 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:22:05 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:25:31 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:26:12 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:26:54 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:27:35 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:28:16 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.50 for 00:00:FA:61:24:FA without success
aug/18 13:43:27 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.106 for 30:A8:DB:BA:8F:B6 without success
aug/18 16:42:44 dhcp,warning dhcp_server_vlan10 client 14:99:E2:B8:52:13 declines IP address 192.168.1.167
aug/18 15:11:12 system,error,critical router was rebooted without proper shutdown
aug/18 15:11:15 interface,info vlan_6 link up
aug/18 15:11:15 interface,info vlan_10 link up
aug/18 15:11:15 interface,info vlan_20 link up
aug/18 15:11:15 interface,info vlan_30 link up
aug/18 15:11:17 pppoe,ppp,info pppoe-out1: initializing…
aug/18 15:11:17 pppoe,ppp,info pppoe-out1: connecting…
aug/18 15:11:18 interface,info ether1-gateway link up (speed 100M, full duplex)
aug/18 15:11:19 pppoe,ppp,info pppoe-out1: authenticated
aug/18 15:11:19 pppoe,ppp,info pppoe-out1: connected
aug/18 15:11:19 system,info item added
aug/18 15:11:19 interface,info ether2 link up (speed 1G, full duplex)
aug/19 05:33:18 system,info sntp change time Aug/18/2017 15:11:44 => Aug/19/2017 05:33:18
aug/19 08:41:19 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.71 for 0C:B3:19:09:87:C5 without success
aug/19 10:03:32 dhcp,warning dhcp_server_vlan10 offering lease 192.168.1.70 for 30:A8:DB:BA:8F:B6 without success
No, that happens after reboot. It is normal for an “unclean” reboot like a crash or powercycle.
The MikroTik routers have no clock. The current time is regularly written to a file, and after a crash or powercycle the clock is first set to that stored time, and then after the network comes up it is reset from SNTP (or from “cloud time” when that is enabled).
All the messages before that are incorrectly timestamped. They show a time that is “in the past” at the moment they are logged.
When you do a clean reboot, the file is written immediately before reboot and the time jump is only a few seconds.
Ok, thanks pe1chl. I got it.
So, I will try to remove it to another mikrotik.
I will write about result.
It’s still worth checking the power supply then. I work with thousands of devices and power supplies of all types commonly go bad.
Also, wiggle the power jack and see what happens. It’s common for components which are soldered to the board but require physical force to manipulate them to become loose on the board. Happens all the time.
