Trying to setup a site to site VPN between PFsense and Mikrotik. From behind the PFsense (192.168.10.0/24)I can ping devices behind the Mikrotik (10.0.0.0/24), but not the other way around. Not sure if this is an issue on the Mikrotik or PFsense, but was hoping someone could see whats going on here or at least say that the Mikrotik config looks good. If it makes any difference, I have the Mikrotik only plugged in with the eth2 interface to the home internet router. From the Mikrotik interface I can ping it’s site of the wireguard tunnel, 192.168.32.2, but not the other side of 192.168.32.1
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridgeLocal \
port-cost-mode=short
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridgeLocal comment=defconf interface=ether1 internal-path-cost=10 \
path-cost=10
add bridge=bridgeLocal comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridgeLocal comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridgeLocal comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridgeLocal comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
/interface wireguard peers
add allowed-address=192.168.32.1/30,192.168.10.0/24 comment=HQ \
endpoint-address=**ELIDED** endpoint-port=**ELIDED** interface=wireguard1 \
persistent-keepalive=25s public-key="**ELIDED**"
add address=192.168.32.2/30 interface=wireguard1 network=192.168.32.0
/ip dhcp-client
add comment=defconf interface=bridgeLocal
add action=accept chain=forward dst-address=192.168.10.0/24 src-address=\
10.0.0.0/24
add action=accept chain=forward dst-address=10.0.0.0/24 src-address=\
192.168.10.0/24
add disabled=no dst-address=192.168.10.0/24 gateway=wireguard1 routing-table=\
main suppress-hw-offload=no
/system clock
set time-zone-name=America/New_York
/system note
set show-at-login=no
