Troughput related Issue
friends i need your i have installed basebox5 with 34dbi mimo dish Antenna over 52 km
i am receiving signal strength some time -65 - 68 some time -88 -89 maximum
Connectivity with tx 3.6 mbps & rx 13.2mbps but while i am trying to give load on that link it is being disconnected one more thing is that both bridge & station bridge are being connected only on
Channel width 10MHz & Band 5GHz- Only-N
Make sure the distance it shows on the connection is correct.
You may need to manually set the distance - it is better to set it too long than too short.
(In Winbox, you need to click the advanced mode button on the wireless interface configuration window, and then switch to the advanced tab)
