trunk vlans across wireless bridge
I have a simple setup, 2 Routerboards running 6.45.8. Ethernet 1 connects to the lan on each side, and the wireless interface extends the network between 2 switches. Ether 1 & wireless interface are bridged. Cisco switches configured for trunking on the connecting port with a native vlan 8.
I just want the two switches to form a trunk across the wireless connection that is bridged together. Making the wireless connection is no problem. Getting the trunk to work across it has been a challenge.
vlan 8 is native vlan for trunk, so would like this to be the untagged bridged interface IP
vlan 5,6,7,10,44 should be tagged across the bridge/wireless link to the other switch
tried many combinations to accomplish this simple task, but cannot make it work. The config is rather simple and currently looks like this on both devices:
add name=bridge1 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
add authentication-types=wpa2-psk eap-methods=“” management-protection=
allowed mode=dynamic-keys name=5GBH supplicant-identity=“”
wpa2-pre-shared-key=xxxxxxxxxx
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-Ceee country=“united states3” disabled=no frequency=auto
frequency-mode=manual-txpower mode=ap-bridge name=xx-xxx-5G-AP
radio-name=xx-xxx-5G-AP security-profile=5GBH ssid=A3Prod5GBH vlan-mode=
use-tag wireless-protocol=802.11
/interface wireless nstreme
set xx-xxx-5G-AP enable-nstreme=yes
add bridge=bridge1 interface=xx-xxx-5G-AP
/interface bridge vlan
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=7
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=44
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=5
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=6
add bridge=bridge1 tagged=ether1,xx-xxx-5G-AP vlan-ids=10
add bridge=bridge1 untagged=ether1,xx-xxx-5G-AP vlan-ids=8
add address=x.x.x.x/24 interface=bridge1 network=x.x.x.x
add distance=1 gateway=x.x.x.x
What am I missing to allow trunk to establish across wireless bridge?
Description is too vague/confusing, draw a network diagram.
For MT devices provide config
not sure why you say it’s too vague
I’m simply trying to extend the network between 2 switches using 2 radios in bridge mode, and it needs to be a layer 2 trunk
diagram attached.
diagram.pdf (23.9 KB)
also full config is already included in original post, there’s not much too it.
If you want the section /interface bridge vlan to have any effect what so ever, you need to /interface bridge set [ find name=bridge1 ] vlan-filtering=yes. If management interface (bridge1 interface) should be member of anything else than VID=1, then you should set appropriate pvid, e.g. /interface bridge set [ find name=bridge1 ] pvid=8.
ok, so if I turn on filtering then it should work, my config looks ok otherwise?
I’m pretty sure I tried that already, but can try again
from the switches perspective, vlan 8 is untagged/native vlan
the mikrotik bridge interface has an IP that corresponds with the subnet of vlan 8
if vlan 8 is untagged towards the mikrotik, would I still need to change the PVID to 8?
Good thing, I only support native vlan1 and not for carrying any data either. :wink:
My contract does not cover native vlan8.
MT doesn’t know that untagged frames, entering through ether1 (and wlan1) are considered as “native VLAN 8” on other devices in LAN, those frames are simply untagged. You’re tagging them on ingress (PVID setting on corresponding bridge ports under /interface bridge port) and untagging on egress (untagged members of corresponding VLAN under /interface bridge vlan). But as you tag frames on ingress through e.g. ether1, those frames are tagged inside bridge (the switch-like personality) and, if PVID is not set on bridge interface, they are expected to be tagged on bridge interface (read more about bridge personalities) … Only that bridge interface in your case is not member of VID 8 in any way (neither untagged nor tagged), bridge interface has implicit default setting of pvid=1 which means that default mikrotik configuration has VLAN ID 1 as “native”. If you want to have VID=8 native, you have to reconfigure ROS in 3 places.
To better understand how VLANs are done in ROS, read through this excellent tutorial.
As I wrote: as long as bridge doesn’t have vlan-filtering=yes, it won’t do tagging/untagging and untagged frames from switches will indeed get to bridge interface untagged and things seem to work fine. If you enable vlan-filtering, then you’ll loose management access to device (you’ll get upset and consider things not working and revert the setting). Unless you fix the bridge interface vlan settings.
