trunked port multiple SSIDs
I’m super new to the Mikrotik environment and I need some help with my home setup.
I want to setup 3 wireless networks:
  1. one for my devices (full access)
  2. one for guests (filtered access to internet only, not my LAN)
  3. one for my home automation, access only to my wired deices in port 4 on my router
I followed several tutorials with no success (includingCAPsMAN). Can anybody help? This is my setup:
Router:
# jun/22/2018 02:52:20 by RouterOS 6.42.2
# software id = VJ0A-JW5R
# model = 951Ui-2HnD
# serial number = 7175xxxx
set [ find default-name=ether1 ] name="ether1 - modem"
set [ find default-name=ether2 ] name="ether2 - LAN"
set [ find default-name=ether3 ] name="ether3 - trunked"
set [ find default-name=ether4 ] name="ether4 - IoT"
set [ find default-name=ether5 ] name="ether5 - DMZ"
/interface pppoe-client
add add-default-route=yes disabled=no interface="ether1 - modem" name=\
    pppoe-out-VodanoneADSL use-peer-dns=yes
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface vlan
add interface="ether3 - trunked" name="vlan2 - WLAN" vlan-id=2
add interface="ether3 - trunked" name="vlan4 - IoT WLAN" vlan-id=4
add interface="ether3 - trunked" name="vlan5 - guest WLAN" vlan-id=5
add name=LAN-IP-pool ranges=192.168.1.10-192.168.1.254
add name=WLAN-pool ranges=192.168.2.10-192.168.2.254
add address-pool=LAN-IP-pool disabled=no interface="ether2 - LAN" name=\
    dhcp-server-LAN
add address-pool=WLAN-pool disabled=no interface="vlan2 - WLAN" name=\
    hhcp-server-WLAN
add address=192.168.0.2/24 interface="ether1 - modem" network=192.168.0.0
add address=192.168.1.1/24 interface="ether2 - LAN" network=192.168.1.0
add address=192.168.2.1/24 interface="vlan2 - WLAN" network=192.168.2.0
add address=192.168.4.1/24 interface="vlan4 - IoT WLAN" network=192.168.4.0
add address=192.168.5.1/24 interface="vlan5 - guest WLAN" network=192.168.5.0
add address=192.168.3.1/24 interface="ether4 - IoT" network=192.168.3.0
add address=192.168.6.1/24 interface="ether5 - DMZ" network=192.168.6.0
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1 netmask=24
add address=192.168.2.0/24 dns-server=8.8.8.8 gateway=192.168.2.1
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=240.0.0.0/4 comment=RFC6890 list=NotPublic
    "Drop new connections from internet which are not dst-natted" \
    connection-nat-state=!dstnat connection-state=new in-interface=\
    "ether1 - modem"
add action=accept chain=input comment="Accept established connections" \
    connection-state=established
add action=accept chain=input comment="Accept related connections" \
    connection-state=related
add action=drop chain=input comment="Drop invalid connections" \
    connection-state=invalid
add action=accept chain=input comment=UDP disabled=yes protocol=udp
add chain=input comment="Allow limited pings" limit=50/5s,2 protocol=icmp
add action=drop chain=input comment=" Drop excess pings" protocol=icmp
add action=accept chain=input comment=" From LAN" in-interface="ether2 - LAN" \
    src-address=192.168.1.0/24
    "Drop all packets which are not destined to routes IP address" \
    dst-address-type=!local
    "Drop all packets which does not have unicast source IP address" \
    src-address-type=!unicast
add action=drop chain=input comment="Drop all packets from public internet whi\
    ch should not exist in public network" in-interface="ether1 - modem" \
    src-address-list=NotPublic
add action=log chain=input comment=" Log everything else" log-prefix=\
    " DROP INPUT"
add action=drop chain=input comment=" Drop everything else"
add action=masquerade chain=srcnat src-address=192.168.1.0/24
add action=masquerade chain=srcnat src-address=192.168.2.0/24
/system clock
set time-zone-name=Europe/Athens
/system identity
set name="MikroTik Router"
/system ntp client
set enabled=yes primary-ntp=194.177.210.54 secondary-ntp=88.198.12.78
/system routerboard settings
set silent-boot=no
Access Point:
# jan/19/1970 02:13:18 by RouterOS 6.41.2
# software id = V9U3-24G1
# model = RouterBOARD cAP L-2nD
# serial number = 7xxxxx
add fast-forward=no name=bridge vlan-filtering=yes
add authentication-types=wpa2-psk eap-methods="" management-protection=\
    allowed mode=dynamic-keys name=K____WLAN_sec_prof \
    supplicant-identity="" wpa2-pre-shared-key=K___
    allowed mode=dynamic-keys name=K____GUEST_sec_prof \
    allowed mode=dynamic-keys name=K____IoT_sec_prof supplicant-identity=\
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
    name=K____WLAN security-profile=K____WLAN_sec_prof ssid=\
    K____WLAN vlan-id=2 vlan-mode=use-tag wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=66:D1:xx:xx:xx:58 \
    master-interface=K____WLAN multicast-buffering=disabled name=\
    K____GUEST security-profile=K____GUEST_sec_prof ssid=\
    K____GUEST vlan-id=5 vlan-mode=use-tag wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=66:D1:xx:xx:xx:59 \
    K____IoT security-profile=K____IoT_sec_prof ssid=K____IoT \
    vlan-id=4 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=\
    disabled
/ip hotspot profile
add bridge=bridge interface=K____WLAN
add bridge=bridge interface=K____IoT
add bridge=bridge interface=K____GUEST
/interface bridge vlan
add bridge=bridge tagged=ether1,K____WLAN vlan-ids=2
add bridge=bridge tagged=ether1,K____IoT vlan-ids=4
add bridge=bridge tagged=ether1,K____GUEST vlan-ids=5
/interface detect-internet
set detect-interface-list=all
/system clock
/system identity
set name=AP_FL0
/system ntp client
set enabled=yes primary-ntp=155.207.113.227 secondary-ntp=193.219.28.147
Thank you!
