Hello all,
I am trying to configure an RB493G as a wireless AP Bridge with 3 separate networks, with port 1 as a trunk, ports 2-5 as vlan 1, ports 6 & 7 as vlan 3, and ports 8 & 9 as vlan 5.
I currently have the trunk working for vlans 3 and 5 using bridges to join the ports and wireless cards. Where I am having an issue, is that I am unable to configure vlan 1 to trunk from our cisco switches since they are untagged. So to bypass it for now i just have a jumper cable between the two physical networks.
My first question is does anyone no how to pass this untagged vlan 1 to a “vlan 1” bridge from a cisco switch?
Also, is the bridge method the best configuration or is there a better way using the switch chip? and how would I set that up? ports 2-5 are all on one switch chip.
thank you.
