vlans and trunking from mikrotik to switches
My organisation has 5 vlans:
management traffic vlanid=3,
cctv traffic vlanid=4,
voip traffic vlanid=5,
office traffic vlanid=6
and hotspot traffic vlanid=7
I want to replace the current router (openwrt) with a mikrotik RB2011iL-RM.
I’m trying to replicate the setup I have on openwrt but my trunk ports (ether 1-5) refuse to communicate with the organisation’s switches (switches work fine when connected to openwrt trunk ports).
# jan/02/1970 08:09:27 by RouterOS 6.12
# software id = QJDL-LB2R
add l2mtu=1594 mtu=1504 name=3-MANAGEMENT
add l2mtu=1594 mtu=1504 name=4-CCTV
add l2mtu=1594 mtu=1504 name=5-VOIP
add l2mtu=1594 mtu=1504 name=6-OFFICE
add l2mtu=1594 mtu=1504 name=7-HOTSPOT
set [ find default-name=ether8 ] name=ether8-WAN1
set [ find default-name=ether9 ] name=ether9-WAN2
/interface vlan
add interface=ether1 l2mtu=1594 name=v3p1 vlan-id=3
add interface=ether2 l2mtu=1594 name=v3p2 vlan-id=3
add interface=ether3 l2mtu=1594 name=v3p3 vlan-id=3
add interface=ether4 l2mtu=1594 name=v3p4 vlan-id=3
add interface=ether5 l2mtu=1594 name=v3p5 vlan-id=3
add interface=ether6 l2mtu=1594 name=v3p6 vlan-id=3
add interface=ether1 l2mtu=1594 name=v4p1 vlan-id=4
add interface=ether2 l2mtu=1594 name=v4p2 vlan-id=4
add interface=ether3 l2mtu=1594 name=v4p3 vlan-id=4
add interface=ether4 l2mtu=1594 name=v4p4 vlan-id=4
add interface=ether5 l2mtu=1594 name=v4p5 vlan-id=4
add interface=ether1 l2mtu=1594 name=v5p1 vlan-id=5
add interface=ether2 l2mtu=1594 name=v5p2 vlan-id=5
add interface=ether3 l2mtu=1594 name=v5p3 vlan-id=5
add interface=ether4 l2mtu=1594 name=v5p4 vlan-id=5
add interface=ether5 l2mtu=1594 name=v5p5 vlan-id=5
add interface=ether1 l2mtu=1594 name=v6p1 vlan-id=6
add interface=ether2 l2mtu=1594 name=v6p2 vlan-id=6
add interface=ether3 l2mtu=1594 name=v6p3 vlan-id=6
add interface=ether4 l2mtu=1594 name=v6p4 vlan-id=6
add interface=ether5 l2mtu=1594 name=v6p5 vlan-id=6
add interface=ether7 l2mtu=1594 name=v6p7 vlan-id=6
add interface=ether1 l2mtu=1594 name=v7p1 vlan-id=7
add interface=ether2 l2mtu=1594 name=v7p2 vlan-id=7
add interface=ether3 l2mtu=1594 name=v7p3 vlan-id=7
add interface=ether4 l2mtu=1594 name=v7p4 vlan-id=7
add interface=ether5 l2mtu=1594 name=v7p5 vlan-id=7
set 0 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 2 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 3 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 4 default-vlan-id=3 vlan-header=add-if-missing vlan-mode=secure
set 5 default-vlan-id=3 vlan-header=always-strip vlan-mode=fallback
set 6 default-vlan-id=6 vlan-header=always-strip vlan-mode=fallback
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add name=dhcp_pool-3-management ranges=10.20.30.2-10.20.30.254
add name=dhcp_pool-4-cctv ranges=10.20.40.2-10.20.40.254
add name=dhcp_pool-5-voip ranges=10.20.50.2-10.20.50.254
add name=dhcp_pool-6-office ranges=10.20.60.2-10.20.60.254
add name=dhcp_pool-7-hotspot ranges=10.20.70.2-10.20.71.254
add address-pool=dhcp_pool-3-management disabled=no interface=3-MANAGEMENT \
name=dhcp-3-management
add address-pool=dhcp_pool-4-cctv disabled=no interface=4-CCTV name=\
dhcp-4-ccctv
add address-pool=dhcp_pool-5-voip disabled=no interface=5-VOIP name=\
dhcp-5-voip
add address-pool=dhcp_pool-6-office disabled=no interface=6-OFFICE name=\
dhcp-6-office
add address-pool=dhcp_pool-7-hotspot disabled=no interface=7-HOTSPOT name=\
dhcp-7-hotspot
add bridge=3-MANAGEMENT interface=v3p1
add bridge=3-MANAGEMENT interface=v3p2
add bridge=3-MANAGEMENT interface=v3p3
add bridge=3-MANAGEMENT interface=v3p4
add bridge=3-MANAGEMENT interface=v3p5
add bridge=3-MANAGEMENT interface=v3p6
add bridge=4-CCTV interface=v4p1
add bridge=4-CCTV interface=v4p2
add bridge=4-CCTV interface=v4p3
add bridge=4-CCTV interface=v4p4
add bridge=4-CCTV interface=v4p5
add bridge=5-VOIP interface=v5p1
add bridge=5-VOIP interface=v5p2
add bridge=5-VOIP interface=v5p3
add bridge=5-VOIP interface=v5p4
add bridge=5-VOIP interface=v5p5
add bridge=6-OFFICE interface=v6p1
add bridge=6-OFFICE interface=v6p2
add bridge=6-OFFICE interface=v6p3
add bridge=6-OFFICE interface=v6p4
add bridge=6-OFFICE interface=v6p5
add bridge=6-OFFICE interface=v6p7
add bridge=7-HOTSPOT interface=v7p1
add bridge=7-HOTSPOT interface=v7p2
add bridge=7-HOTSPOT interface=v7p3
add bridge=7-HOTSPOT interface=v7p4
add bridge=7-HOTSPOT interface=v7p5
add independent-learning=no ports=ether1,ether2,ether3,ether4,ether5 switch=\
switch1 vlan-id=3
switch1 vlan-id=4
switch1 vlan-id=5
switch1 vlan-id=6
switch1 vlan-id=7
add ports=ether6 switch=switch2 vlan-id=3
add ports=ether7 switch=switch2 vlan-id=6
add address=10.20.30.1/24 interface=3-MANAGEMENT network=10.20.30.0
add address=10.20.40.1/24 interface=4-CCTV network=10.20.40.0
add address=10.20.50.1/24 interface=5-VOIP network=10.20.50.0
add address=10.20.60.1/24 interface=6-OFFICE network=10.20.60.0
add address=10.20.70.1/23 interface=7-HOTSPOT network=10.20.70.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether8-WAN1
add default-route-distance=0 dhcp-options=hostname,clientid interface=\
ether9-WAN2
add address=10.20.30.0/24 dns-server=10.20.30.1 gateway=10.20.30.1
add address=10.20.40.0/24 dns-server=10.20.40.1 gateway=10.20.40.1
add address=10.20.50.0/24 dns-server=10.20.50.1 gateway=10.20.50.1
add address=10.20.60.0/24 dns-server=10.20.60.1 gateway=10.20.60.1
add address=10.20.70.0/23 dns-server=10.20.70.1 gateway=10.20.70.1
set allow-remote-requests=yes servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=ether8-WAN1
add action=masquerade chain=srcnat out-interface=ether9-WAN2
I can’t pass any traffic whatsoever from the router to a switch.
I’m using routeros 6.12
