we recently mounted a wireless network with a lot of APs in a very big and in-movement site. Lots of trucks and machines moving. It’s a container terminal were my customer handle a massive volume of containers. You can see a panorama here:
As we installed 15 APs with 2 radios to serve 8 Futurepad I think the number of antennas is OK. We are using 2.4GHz, 14dBi pannels and 120 degree sectors, depending on the site of coverage. The APs are installed at 25 meters height and the antennas are pointing to the floor.
The futurepads has 2 or 3 diferent versions, but the one I opened has a CM9 on it. We have to use 2.4GHz freq for this. We have 2 more APs working with 5GHz for big machines that are statically working during the day.
If we are walking around ALL the container terminal, in and out of container stacks, across the streets, from right to left, with our DELL Latitude 630, we have no problems and the roaming is very good. We always can ping the server without problems and we can see that the laptop is doing roaming very good (when the ping grows and you lose a packet or two).
The problem comes with the Futurepads. I’m sure the futurepads are doing roaming diferently. This embedded windows machine is waiting to make roaming till the connection is lost or is very bad (I can see signals of -9x) and the machine stays there.. The problem is that a machine connects to the AP1 with -50 of signal and stays there till -9x signal. You can stay in from of AP2 and receiving -60 signal, but the AP1 still being the connected AP.
If you disconnect the wireless and reconnect it, then it connects to AP2, of course.
We noticed that the wireless software has 5 types of roaming to configure (very low, low, normal, agressive and extreme), but we tryed many and it works same xD
We tryed to configure signal level in the APs, but.. once you are conected there with a good signal, the AP don’t drop you when you reach the limit.. then, the AP only limits the connection if you try to connect to it with a bad signal.
We tried to reduce power from the APs, but it’s the same.
Why the laptop is working well and the futurepads aren’t? Can we try something else to fix this issue? The problem is when the ping goes to 50-100-150-200 ms and the futurepad stay connected, the program server drops the machine and you have to reconnect to the program and people that is working with the futurepads has to make his work very fast, because are very busy…
Thanks!
