I’m trying to add a VLAN to segregate an SSID. I thought it would be pretty straight forward, and I’v done plenty of work with VLANs in the past (but not router OS), But I can’t seem to get it to “work”.
Steps I’ve taken:
Added a VLAN interface (named it alexa) and attached it to the bridge. (The bridge is basically ether2-ether5, local LAN traffic)
/interface vlan print
# NAME MTU ARP VLAN-ID INTERFACE
0 R alexa 1500 enabled 90 bridge
Assigned an IP address to the VLAN:
/ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; defconf
192.168.80.1/24 192.168.80.0 bridge
2 192.168.90.1/32 192.168.90.1 alexa
Added a DHCP pool for the VLAN:
/ip pool print
# NAME RANGES
0 default-dhcp 192.168.80.50-192.168.80.254
1 alex_pool 192.168.90.50-192.168.90.254
The assigned IP address, 192.168.90.1, is up and active.
Added a datapath in CAPsMAN:
/caps-man datapath print
0 name="datapath1" bridge=bridge local-forwarding=no
1 name="alexa_datapath" bridge=bridge local-forwarding=no vlan-mode=use-tag vlan-id=90
Then I added a new configuration in CAPsMAN and assigned it to the datapath.
(Omitted config)
The SSID shows up, and I can connect to it. However, no IP address is assigned from DHCP. So, I must be missing a configuration, or an option somewhere.
