I am trying to get a RB750Gr3 running RouterOS 7.20 to provide stateful firewall services on a bridge which has 3 ports joined.
This is a basic summary of the setup and the goals
| interface | bridge | purpose | firewall objectives |
| ether1-LAN-mgmt | n/a | management of Router, not part of bridge | n/a |
| ether2-protected-connectivity | protected-bridge | provide connectivity for protected-bridge | allow established ingress, allow any egress, default deny |
| ether3-protected-device1 | protected-bridge | provide transparent firewall to device 1 | allow any |
| ether4-protected-device2 | protected-bridge | provide transparent firewall to device 2 | allow any |
Other notes
- ether2 is on the untrusted side
- ether3 and ether4 are on the trusted side
- hardware offload is disabled for ether2-4 as part of being members of protected-bridge
Things I've tried and Problems I've found
Bridge Filter approach
/interface bridge filter
add action=drop chain=forward comment="default deny" log=yes
- I can't find a way to get bridge filter rules to incorporate a state(to allow established etc.), so that traffic from the untrusted side can respond to connections initiated from the trusted side
Firewall rules approach
using interface lists
add name=protected-external
add name=protected-internal
add interface=ether2-protected-connectivity list=protected-external
add interface=ether3-protected-hpvr list=protected-internal
add interface=ether4-protected-spare list=protected-internal
set enabled=yes udp-timeout=10s
add action=accept chain=forward comment="allow all egress from protected-external" log=yes out-interface-list=protected-external
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked in-interface-list=protected-external log=yes
add action=drop chain=forward comment="default drop" in-interface-list=protected-external log=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
- pings can be initiatited from devices on protected-external side, so above rules have no effect
directly selecting interfaces
# in/out-interface matcher not possible when interface (ether2-protected-connectivity) is slave - use master instead (protected)
add action=accept chain=forward comment="allow all egress from protected-external" log=yes out-interface=ether2-protected-connectivity
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked in-interface=ether2-protected-connectivity log=yes
add action=drop chain=forward comment="default drop" in-interface=ether2-protected-connectivity log=yes
- I'm unable to directly configure an outbound interface for those interfaces that are in a bridge
Overall I'm not sure what my options are, I haven't used transparent firewall configurations on a RouterOS before.
Have I missed something or are there limitations I might not be aware of?
Thanks in advance for any suggestions.
