In the screenshot it says 1gb connection. Cable test runs ok. The CLI shows 100mb on the hEX. Not sure if it is a bug, something is incorrect, or if I am missing something. Just tryig to verify I am actually at 1GB and not 100MB.
FYSA, I have verified the cables are CAT 6 UTP and do pass testing.
wAP AC Config
# sep/14/2018 21:40:14 by RouterOS 6.43
# software id = KUAN-KIBF
# model = RouterBOARD wAP G-5HacT2HnD
# serial number = 824E089E9ED4
add name=bridge1
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile-internal supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge name=wlan-wap-internal-2 security-profile=profile-internal ssid=LMAM-wAP-Internal-2 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-onlyac disabled=no mode=ap-bridge name=wlan-wap-internal-5 security-profile=profile-internal ssid=LMAM-wAP-Internal-5 wps-mode=disabled
/ip hotspot profile
add bridge=bridge1 interface=wlan-wap-internal-2
add bridge=bridge1 hw=no interface=ether1
add bridge=bridge1 interface=wlan-wap-internal-5
add address=10.60.1.10/24 interface=ether1 network=10.60.1.0
set servers=10.60.1.1
add distance=1 gateway=10.60.1.1
/system clock
set time-zone-name=America/Chicago
/system ntp client
set enabled=yes server-dns-names=pool.ntp.org
/system routerboard settings
set silent-boot=no
hEX Config
# sep/14/2018 21:42:01 by RouterOS 6.43
# software id = 1XFR-66DY
# model = RouterBOARD 750G r3
# serial number = 8B0008146D97
add admin-mac=CC:2D:E0:B5:94:AA auto-mac=no name=bridge-internal protocol-mode=none
set [ find default-name=ether1 ] name=ether1-router speed=100Mbps
set [ find default-name=ether2 ] name=ether2-hapac2 speed=100Mbps
set [ find default-name=ether3 ] name=ether3-rb2011 speed=100Mbps
set [ find default-name=ether4 ] name=ether4-asus speed=100Mbps
set [ find default-name=ether5 ] name=ether5-wAPac speed=100Mbps
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=8h pfs-group=none
add name=pool-core ranges=10.100.0.100-10.100.0.200
add name=pool-Guest ranges=10.50.1.100-10.50.1.200
add name=pool-internal-2 ranges=10.60.1.100-10.60.1.200
add address-pool=pool-core disabled=no interface=bridge-internal name=dhcpserver-core
add address-pool=pool-Guest disabled=no interface=ether3-rb2011 name=dhcpserver-guest
add address-pool=pool-internal-2 disabled=no interface=ether5-wAPac name=dhcpserver-internal-2
/ipv6 dhcp-server
add address-pool=IPv6-local-pool comment="IPv6 DHCP Server" interface=ether1-router lease-time=10m name=server1
add bridge=bridge-internal interface=ether4-asus
add bridge=bridge-internal interface=ether2-hapac2
set discover-interface-list=discover
/interface l2tp-server server
set max-mru=1460 max-mtu=1460
add comment=defconf interface=bridge-internal list=LAN
add comment=defconf interface=ether1-router list=WAN
add interface=bridge-internal list=discover
add interface=ether3-rb2011 list=discover
add interface=ether4-asus list=discover
add interface=ether5-wAPac list=discover
add interface=bridge-internal list=mactel
add interface=bridge-internal list=mac-winbox
add interface=ether3-rb2011 list=LAN
add interface=ether3-rb2011 list=mac-winbox
/interface ovpn-server server
set auth=sha1 cipher=aes128,aes192,aes256 require-client-certificate=yes
/interface pptp-server server
set authentication=chap,mschap1,mschap2 default-profile=default
add address=10.100.0.1/24 interface=bridge-internal network=10.100.0.0
add address=10.50.1.1/24 interface=ether3-rb2011 network=10.50.1.0
add address=10.60.1.1/24 interface=ether5-wAPac network=10.60.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1-router
add address=10.50.1.0/24 comment="Internal - Guest" gateway=10.50.1.1 netmask=24
add address=10.60.1.0/24 comment="wAP ac" gateway=10.60.1.1 netmask=24
add address=10.100.0.0/24 comment="Internal - Primary" gateway=10.100.0.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=10.100.0.0/24 list=Internal-All
add address=10.50.1.0/24 list=Internal-All
add address=10.100.0.0/24 list=Internal-Trusted
add address=10.50.1.0/24 list=Internal-Restricted
add address=10.60.1.0/24 list=Internal-All
add address=10.60.1.0/24 list=Internal-Trusted
add action=accept chain=input comment="Allow All Trusted" src-address-list=Internal-Trusted
add action=accept chain=input comment="Allow DNS All" dst-port=53 protocol=udp src-address-list=Internal-All
add action=accept chain=input comment="All NTP All" protocol=udp src-address-list=Internal-All src-port=123
add action=accept chain=input comment="defconf: accept ICMP" dst-limit=30,30,dst-address/1m40s limit=30,30:packet protocol=icmp
add action=reject chain=forward comment="Restricted to Trusted Blocked" dst-address-list=Internal-Trusted reject-with=icmp-network-unreachable src-address-list=Internal-Restricted
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=ether1-router
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=10.100.0.0/24,10.60.0.0/24
set api disabled=yes
set winbox address=10.100.0.0/24,10.60.0.0/24
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ipv6 address
add from-pool=IPv6-local-pool interface=bridge-internal
/ipv6 dhcp-client
add add-default-route=yes comment="Main DHCP IPv6 Pool" interface=ether1-router pool-name=IPv6-local-pool request=prefix
/system clock
/system identity
set name=hex-1
/system ntp client
set enabled=yes primary-ntp=132.163.96.5 secondary-ntp=129.6.15.32 server-dns-names=pool.ntp.org
/system resource irq rps
set ether1-router disabled=no
set ether3-rb2011 disabled=no
set ether4-asus disabled=no
set ether5-wAPac disabled=no
set ether2-hapac2 disabled=no
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
