I am having a bit of a problem figuring out how to get started with the firewall. My setup is all VLANS are coming in on 1 physical interface, it is my understanding that since I am only using one physical interface, I don’t need a bridge? You can see in the config below that there is a bridge setup, I have tried to add the vLAN interfaces to the bridge but I am having the same issue.
My target setup is that the router will DHCP to all VLANS, all VLANS will be blocked/isolated from each other with the exception that certain ports from certain IPs can make it through, it’ll pretty much be 2 TCP ports at most need to make it through.
Through my reading on the forums, the router by default should let traffic through, and that seemed to be the case. When I nuked the config and setup again, my computer on 10.201.2.xxx could ping a computer on 10.201.131.xxx. As a test, I added a firewall rule to chain forward, action drop from all vLAN to all vLAN interfaces, with that the pings between vLANs stopped. When I disabled or deleted the rule the pings still didn’t start back up, even after a router reboot. I even tried to make the same rule but with an accept action.
Thank you for any help or insight! This is an isolated system as a test bench before we go live, so I can try any suggestions. I have my windows workstation and an iMac on vLANs 2 & 301 and I have a laptop on vLAN 1 for admin purposes. All 3 machines can access & ping the router’s address in their respected subnet. There isn’t and will never be internet to the router.
# jan/02/1970 17:08:17 by RouterOS 7.8
# software id = QL38-T7L7
# model = CCR2004-1G-12S+2XS
# serial number = dhrjene
add name=bridge1
set [ find default-name=sfp-sfpplus1 ] name=ProductionNetwork
/interface vlan
add interface=bridge1 name=vlan2-TheMiddle vlan-id=2
add interface=bridge1 name=vlan301-AJPT_QLAN vlan-id=301
add name=WAN
add name=LAN
add name=TheMiddle ranges=10.201.2.201-10.201.2.254
add name=AJPTQLAN ranges=10.201.101.254-10.201.131.201
add address-pool=TheMiddle interface=vlan2-TheMiddle name=TheMiddle_DHCP
add address-pool=AJPTQLAN interface=vlan301-AJPT_QLAN name=AJPTQLAN
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge1 interface=ProductionNetwork
add interface=ProductionNetwork list=WAN
add list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
add address=10.201.1.1/24 interface=ProductionNetwork network=10.201.1.0
add address=10.201.2.1/24 interface=vlan2-TheMiddle network=10.201.2.0
add address=10.201.131.0/24 interface=vlan301-AJPT_QLAN network=10.201.131.0
add address=10.201.2.0/24 dns-none=yes gateway=10.201.2.1 netmask=24
add address=10.201.131.0/24 dns-none=yes gateway=10.201.131.1
/system routerboard settings
set enter-setup-on=delete-key
Anav, I appreciate the input, I have read that thread a few times now over the last couple days and maybe I’m missing something, here is the updated config as it stands now after following the tutorial to the best of my abilities with my setup.
Thus it should look like this and can be shortened too. /interface bridge vlan add bridge=bridge1 tagged=bridge1,ProductionNetwork vlan-ids=2,301
You have an empty list member entry and should remove it…
add interface=ProductionNetwork list=WAN add list=LAN
add interface=vlan2-TheMiddle list=VLAN
add interface=vlan301-AJPT_QLAN list=VLAN
Do not understand??
You have two vlans, WTF is this… add address=10.201.1.1/24 interface=ProductionNetwork network=10.201.1.0
You have no DHCP server for this ghost production network, nor any pool identified!!!
Am I to assume you have a private IP and this router is behind another Router ( double NAT )?
I ask because the firewall is very minimal but covers the bases I suppose.
You should put most of the defaults back in though.
One comment, can you explain to me what the practical difference is between these two rules!!
add action=accept chain=input comment=“Allow VLAN” in-interface-list=VLAN
add action=accept chain=input comment=“Allow Base full access” in-interface=bridge1
