Trying to get my iPhone to connect to my RouterOS with L2TP
I have successfully set up L2TP on my RB750G, I can connect when my iPhone is connected to local lan (rb ip: 192.168.1.1 iPhone IP: 192.168.1.250)
If I switch of wireless from my iPone and try the same over 3G it doesn’t work anymore. I have no idea what I’m doing wrong.
Here my config:
# mar/21/2010 20:49:41 by RouterOS 4.6
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
/ip ipsec peer
add address=0.0.0.0/0:500 auth-method=pre-shared-key comment="" dh-group=modp1024 disabled=no dpd-interval=disable-dpd dpd-maximum-failures=1 enc-algorithm=3des exchange-mode=main generate-policy=yes hash-algorithm=sha1 lifebytes=0 \
    lifetime=1d nat-traversal=no proposal-check=obey secret=****** send-initial-contact=yes
/ip ipsec peer
    lifetime=1d nat-traversal=no proposal-check=obey secret=***** send-initial-contact=yes
Successful connection over local IP
20:16:56 ipsec respond new phase 1 negotiation: 192.168.1.1[500]<=>192.168.1.250[500]
20:16:56 ipsec begin Identity Protection mode.
20:16:56 ipsec received Vendor ID: RFC 3947
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-08
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-06
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-05
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-04
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
20:16:56 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
20:16:56 ipsec
20:16:56 ipsec received Vendor ID: DPD
20:16:56 ipsec ISAKMP-SA established 192.168.1.1[500]-192.168.1.250[500] spi:7f07341ef01ee630:032133f662cfba14
20:16:57 ipsec respond new phase 2 negotiation: 192.168.1.1[500]<=>192.168.1.250[500]
20:16:57 ipsec no policy found, try to generate the policy : 192.168.1.250/32[49163] 192.168.1.1/32[1701] proto=udp dir=in
20:16:57 ipsec trns_id mismatched: my:3DES peer:AES
20:16:57 ipsec IPsec-SA established: ESP/Transport 192.168.1.250[0]->192.168.1.1[0] spi=98895759(0x5e5078f)
20:16:57 ipsec IPsec-SA established: ESP/Transport 192.168.1.1[0]->192.168.1.250[0] spi=98628188(0x5e0f25c)
20:16:57 l2tp,ppp,info <l2tp-0>: waiting for call...
20:16:58 l2tp,ppp,info <l2tp-0>: authenticated
20:16:58 l2tp,ppp,info <l2tp-0>: connected
20:16:58 l2tp,ppp,info,account iphone logged in, 1.1.1.2
Connection from external IP
20:19:00 ipsec respond new phase 1 negotiation: 213.141.117.108[500]<=>194.24.158.2[23655]
20:19:00 ipsec begin Identity Protection mode.
20:19:00 ipsec received Vendor ID: RFC 3947
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-08
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-06
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-05
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-04
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
20:19:00 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
20:19:00 ipsec
20:19:00 ipsec received Vendor ID: DPD
20:19:01 ipsec ISAKMP-SA established 213.141.117.108[500]-194.24.158.2[23655] spi:9b1a26a96f00d68a:caeca333c89ef7ed
20:19:02 ipsec respond new phase 2 negotiation: 213.141.117.108[500]<=>194.24.158.2[23655]
20:19:02 ipsec no policy found, try to generate the policy : 10.100.198.228/32[49165] 213.141.117.108/32[1701] proto=udp dir=in
20:19:02 ipsec trns_id mismatched: my:3DES peer:AES
20:19:02 ipsec IPsec-SA established: ESP/Transport 194.24.158.2[0]->213.141.117.108[0] spi=109031144(0x67faee8)
20:19:02 ipsec IPsec-SA established: ESP/Transport 213.141.117.108[0]->194.24.158.2[0] spi=49812715(0x2f814eb)
I have no clue where the IP 10.100.198.228/32 is coming from.
Any help would be appreciated.
Don’t know about other providers, but on AT&T you get a private IP address that is PAT’d by AT&T. ESP requires NAT-T to work with PAT, so try turning that on.
unfortunately no lock with nat-t enabled.
08:26:53 system,info,account user admin logged in from 192.168.1.3 via winbox
08:27:03 ipsec 213.141.117.108[4500] used for NAT-T
08:27:03 ipsec 10.16.30.1[4500] used for NAT-T
08:27:03 ipsec 192.168.1.1[4500] used for NAT-T
08:27:03 system,info ipsec peer changed by admin
08:27:32 ipsec respond new phase 1 negotiation: 213.141.117.108[500]<=>194.24.158.1[53120]
08:27:32 ipsec begin Identity Protection mode.
08:27:32 ipsec received Vendor ID: RFC 3947
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-08
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-06
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-05
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-04
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
08:27:32 ipsec received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
08:27:32 ipsec
08:27:32 ipsec received Vendor ID: DPD
08:27:32 ipsec Selected NAT-T version: RFC 3947
08:27:32 ipsec Hashing 213.141.117.108[500] with algo #2
08:27:32 ipsec NAT-D payload #0 verified
08:27:32 ipsec Hashing 194.24.158.1[53120] with algo #2
08:27:32 ipsec NAT-D payload #1 doesn't match
08:27:32 ipsec NAT detected: PEER
08:27:32 ipsec Adding remote and local NAT-D payloads.
08:27:32 ipsec NAT-T: ports changed to: 194.24.158.1[53122]<->213.141.117.108[4500]
08:27:32 ipsec KA list add: 213.141.117.108[4500]->194.24.158.1[53122]
08:27:32 ipsec ISAKMP-SA established 213.141.117.108[4500]-194.24.158.1[53122] spi:b2d0c1e77a137307:321e8e89ef21b294
08:27:33 ipsec respond new phase 2 negotiation: 213.141.117.108[4500]<=>194.24.158.1[53122]
08:27:33 ipsec no policy found, try to generate the policy : 10.100.123.163/32[49152] 213.141.117.108/32[1701] proto=udp dir=in
08:27:33 ipsec Adjusting my encmode UDP-Transport->Transport
08:27:33 ipsec Adjusting peer's encmode UDP-Transport(4)->Transport(2)
08:27:33 ipsec trns_id mismatched: my:3DES peer:AES
08:27:34 ipsec IPsec-SA established: ESP/Transport 194.24.158.1[53122]->213.141.117.108[4500] spi=228076702(0xd982c9e)
08:27:34 ipsec IPsec-SA established: ESP/Transport 213.141.117.108[4500]->194.24.158.1[53122] spi=60891111(0x3a11fe7)
LE: I just noticed this is kind of a double post. My problem sounds much like this topic: http://forum.mikrotik.com/t/ipsec-and-nat-t-problem/30115/1
I was able to silence that error with:
/ip ipsec proposal set default enc-algorithms=aes-256
Still unable to make my iPhone connect though. :frowning:
I know that on Rogers (3G in Canada) you are required to have VPN access. I have this b/c I need it for work.
It gives my phone a public IP vs 10.x.x.x. Try from another location via wifi.
