Well, i hope to get rid of all the mierda left XD
On ether3 → Proxmox server (expects tagged traffic) - vlan 10 and 30
iether4- → unmanaged swutch (untagged vlan 10)
ether5 → Aruba switch (all vlan 10, 20, 30)
On the Aruba until now i’v got on port1 - a trunk port with all 3 vlans.
on port2 a proxmox server with vlans 10 and 20.
and on port 3 an access port where my PC is connected with vlan 10.
# oct/07/2022 y:45:29 by RouterOS 6.49.6
# software id = J13U-JGF2
# model = 2011UiAS
add name=BridgeVLAN vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-Claro speed=100Mbps
set [ find default-name=ether2 ] name=ether2-Fibercorp speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full disabled=yes
set [ find default-name=ether7 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full disabled=yes \
name=ether7-Trunk
set [ find default-name=ether8 ] advertise=\
set [ find default-name=ether9 ] advertise=\
set [ find default-name=ether10 ] advertise=\
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=BridgeVLAN name=vlan10-LAN vlan-id=10
add interface=BridgeVLAN name=vlan20-Clientes vlan-id=20
add interface=BridgeVLAN name=vlan30-Camaras vlan-id=30
add name=WAN
add name=VLAN
add name=ADMIN
add name=dhcp_10 ranges=10.0.10.2-10.0.10.99
add name=dhcp_20 ranges=10.0.20.2-10.0.20.254
add name=dhcp_30 ranges=10.0.30.2-10.0.30.254
add address-pool=dhcp_10 disabled=no interface=vlan10-LAN name=dhcp1
add address-pool=dhcp_20 disabled=no interface=vlan20-Clientes name=dhcp2
add address-pool=dhcp_30 disabled=no interface=vlan30-Camaras name=dhcp4
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/system logging action
add email-to=xxxx@gmail.com name=email target=email
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=BridgeVLAN comment=BridgeVLAN frame-types=admit-only-vlan-tagged \
ingress-filtering=yes interface=ether3
add bridge=BridgeVLAN frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=ether4
add bridge=BridgeVLAN frame-types=admit-only-vlan-tagged ingress-filtering=\
yes interface=ether5
set discover-interface-list=ADMIN
/interface bridge vlan
add bridge=BridgeVLAN tagged=BridgeVLAN,ether3,ether5 untagged=ether4 \
vlan-ids=10
add bridge=BridgeVLAN tagged=BridgeVLAN,ether5 vlan-ids=20
add bridge=BridgeVLAN tagged=BridgeVLAN,ether3,ether5 vlan-ids=30
add interface=ether1-Claro list=WAN
add interface=ether2-Fibercorp list=WAN
add interface=vlan10-LAN list=VLAN
add interface=vlan30-Camaras list=VLAN
add interface=vlan20-Clientes list=VLAN
add interface=ether10 list=ADMIN
add interface=vlan10-LAN list=ADMIN
add address=10.0.10.1/24 interface=vlan10-LAN network=10.0.10.0
add address=10.0.20.1/24 interface=vlan20-Clientes network=10.0.20.0
add address=10.0.30.1/24 interface=vlan30-Camaras network=10.0.30.0
add address=192.168.99.1/24 comment="acceso secundario" interface=ether10 \
network=192.168.99.0
/ip dhcp-client
add comment="Proveedor 1 - Claro" disabled=no interface=ether1-Claro
add add-default-route=no comment="Proveedor 2 - Fibercorp" disabled=no \
add address=10.0.10.0/24 gateway=10.0.10.1
add address=10.0.20.0/24 gateway=10.0.20.1
add address=10.0.30.0/24 gateway=10.0.30.1
set allow-remote-requests=yes servers=1.1.1.2,9.9.9.9
/ip firewall address-list
add address=10.0.10.1-10.0.10.101 comment="Resto de la red" list=a_fibercorp
add address=10.0.10.201 comment=webserver list=a_claro
add address=10.0.10.250-10.0.10.254 comment=Servidores list=a_fibercorp
add address=10.0.20.0/24 comment=Clientes list=a_claro
add address=10.0.10.7 comment=Des07 list=a_claro
add address=10.0.10.102 comment=cosag list=a_claro
add address=10.0.10.103 comment=w2019 list=a_claro
established,related,untracked
invalid
add action=accept chain=input comment="Allow admin to config router" \
in-interface-list=ADMIN
add action=accept chain=input comment="Allow LAN DNS queries-UDP" dst-port=53 \
in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow LAN DNS queries-TCP" dst-port=53 \
in-interface-list=VLAN protocol=tcp
add action=drop chain=input comment="drop all else"
connection-state=established,related in-interface-list=WAN
connection-state=invalid
add action=accept chain=forward comment="VLAN Internet Access only" \
connection-state="" in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward comment="allow admin access to vlans" \
connection-state="" in-interface=vlan10-LAN out-interface=vlan20-Clientes
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
/ip firewall mangle
add action=mark-routing chain=prerouting comment=\
"Env\EDo de tr\E1fico a Fibercorp (ISP2)" new-routing-mark=a-fibercorp \
src-address-list=a_fibercorp
"Env\EDo de tr\E1fico a Claro (ISP1)" new-routing-mark=a-claro \
src-address-list=a_claro
add action=dst-nat chain=dstnat comment=cosag dst-port=xxx \
in-interface-list=WAN protocol=tcp to-addresses=10.0.10.102 to-ports=xxxx
add action=dst-nat chain=dstnat comment=servidor_cp dst-port=3389 \
in-interface-list=WAN protocol=tcp to-addresses=10.0.10.101 to-ports=3389
add action=dst-nat chain=dstnat comment=des07 dst-port=xxx \
in-interface-list=WAN protocol=tcp to-addresses=10.0.10.7 to-ports=xxx
add action=dst-nat chain=dstnat comment=w2019 dst-port=xxx \
in-interface-list=WAN protocol=tcp to-addresses=10.0.10.103 to-ports=xxxx
add action=dst-nat chain=dstnat comment=webserver dst-port=80 \
in-interface-list=WAN protocol=tcp to-addresses=10.0.10.201 to-ports=80
add action=dst-nat chain=dstnat comment=ftp dst-port=21 in-interface-list=WAN \
protocol=tcp to-addresses=10.0.10.101 to-ports=21
add check-gateway=ping comment="Ruta principal Fibercorp" distance=1 gateway=\
x.x.x.x routing-mark=a-fibercorp
add check-gateway=ping comment="Respaldo Fibercorp" distance=2 gateway=\
add check-gateway=ping comment="Ruta principal Claro" distance=1 gateway=\
x.x.x.x routing-mark=a-claro
add check-gateway=ping comment="Respaldo Claro" distance=2 gateway=\
/ip traffic-flow
set enabled=yes interfaces=ether1-Claro
/lcd interface
add
/lcd interface pages
set 0 interfaces="sfp1,ether1-Claro,ether2-Fibercorp,ether3,ether4,ether5,ethe\
r6,*8,ether8,ether9,ether10"
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system logging
add action=email topics=ups
/system scheduler
add interval=5m name="cada 5 minutos" on-event=update_gateways policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=aug/25/2022 start-time=11:00:00
/system script
add dont-require-permissions=no name=update_gateways owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
local newgw [ip dhcp-client get [find interface=\"ether1-Claro\"] gateway]\
;\r\
\n:local routegw [/ip route get [find comment=\"Ruta principal Claro\"] ga\
teway ];\r\
\n:if (\$newgw != \$routegw) do={\r\
\n /ip route set [find comment=\"Ruta principal Claro\"] gateway=\$new\
gw;\r\
\n}\r\
\n:local routegw [/ip route get [find comment=\"Respaldo Fibercorp\"] gate\
way ];\r\
\n /ip route set [find comment=\"Respaldo Fibercorp\"] gateway=\$newgw\
;\r\
\n}\r\
\n:local newgw [ip dhcp-client get [find interface=\"ether2-Fibercorp\"] g\
ateway];\r\
\n:local routegw [/ip route get [find comment=\"Ruta principal Fibercorp\"\
] gateway ];\r\
\n /ip route set [find comment=\"Ruta principal Fibercorp\"] gateway=\
\$newgw;\r\
\n}\r\
\n:local routegw [/ip route get [find comment=\"Respaldo Claro\"] gateway \
];\r\
\n /ip route set [find comment=\"Respaldo Claro\"] gateway=\$newgw;\r\
\n}"
/system ups
add name=APC900 offline-time=10h
/tool e-mail
set address=smtp.gmail.com from=xxxx@gmail.com port=zzz start-tls=\
yes user=xxxx
/tool mac-server mac-winbox
set allowed-interface-list=ADMIN
/tool romon
set enabled=yes
